thinkgeo.mapsuite.wpfdesktopedition.overlaydrawnwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
      • ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs
OverlayDrawnWpfMapEventArgs()
Constructor of OverlayDrawnWpfMapEventArgs class.
This is the default constructor. If you use this constructor then you need to set the required properties manually.
OverlayDrawnWpfMapEventArgs(Overlay,RectangleShape)
  • overlay
    • Type:Overlay
    • Description:This parameter is the overlay that has been drawn.
  • targetExtent
    • Description:This parameter is the world extent that has been drawn.
Overlay
Gets or sets the overlay you have drawn.
TargetExtent
The property gets or sets the drawing extent of current overlay.
thinkgeo.mapsuite.wpfdesktopedition.overlaydrawnwpfmapeventargs.1442546065.txt.gz · Last modified: 2015/09/18 03:14 by admin
