<!– Class –> This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn. This event allows you draw something with the canvas after the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs
![]() | Constructor of OverlayDrawnWpfMapEventArgs class. | ||
![]() | Overlay, RectangleShape | Constructor of OverlayDrawnWpfMapEventArgs class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Overlay | Gets or sets the overlay you have drawn. | |
![]() | RectangleShape | The property gets or sets the drawing extent of current overlay. |
This is the default constructor. If you use this constructor then you need to set the required properties manually.
Name | Type | Description |
This constructor allows you to set the overlay drawn, the world extent and the image you have drawn on.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#OverlayDrawnWpfMapEventArgs.28Overlay.2C_RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#OverlayDrawnWpfMapEventArgs.28Overlay.2C_RectangleShape.29</a>
overlay | Overlay<!– ThinkGeo.MapSuite.WpfDesktopEdition.Overlay –> | This parameter is the overlay that has been drawn. |
targetExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the world extent that has been drawn. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#ToString.28.29</a>
String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
Return Type |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#TargetExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.OverlayDrawnWpfMapEventArgs#TargetExtent</a>
Return Type |
