thinkgeo.mapsuite.wpfdesktopedition.markerzoomlevelset
ThinkGeo.MapSuite.WpfDesktopEdition.MarkerZoomLevelSet
<!– Class –> This class represents a collection of MarkerZoomLevel that determines the appearance of markers at different zoomlevels.
This class represents a collection of &lt;strong&gt;MarkerZoomLevel&lt;/strong&gt;. Each &lt;strong&gt;MarkerZoomLevel&lt;/strong&gt; has a different scale and style definition which will be applied to markers when it is the current zoomlevel.The MarkerZoomLevelSet decides which zoomlevel applys its styles to the markers base on the current zoomlevel.If current zoomlevel is level 03 and we defined the styles on zoomlevel as below:markerOverlay.ZoomLevelSet.ZoomLevel04.DefaultMarkerStyle.WebImage = …; markerOverlay.ZoomLevelSet.ZoomLevel04.DefaultMarkerStyle.Popup = …; markerOverlay.ZoomLevelSet.ZoomLevel04.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level10;then no zoomlevel will apply styles to the markers. There will be no markers display on the screen.When we change the current zoomlevel to level 04, now current zoomlevel falls into the zoomlevel range (04-10) that defines styles. The ZoomlevelSet will apply the styles on the zoomlevel 04 to the markers.
Public MethodMarkerZoomLevelSet Initialize a new instance of the MarkerZoomLevelSet class.
Public MethodGetType Object
Public MethodGetZoomLevelForDrawing Int32 Returns the MarkerZoomLevel object whose styles will be applies to the markers base on the current zoomlevel that passed in.
Public MethodToString Object
Public PropertyCustomZoomLevels Collection<MarkerZoomLevel> Gets a MarkerZoomLevel collection that is used for you to define your own custom zoomlevels.
Public PropertyZoomLevel01 MarkerZoomLevel Gets the MarkerZoomLevel for Level01.
Public PropertyZoomLevel02 MarkerZoomLevel Gets the MarkerZoomLevel for Level02.
Public PropertyZoomLevel03 MarkerZoomLevel Gets the MarkerZoomLevel for Level03.
Public PropertyZoomLevel04 MarkerZoomLevel Gets the MarkerZoomLevel for Level04.
Public PropertyZoomLevel05 MarkerZoomLevel Gets the MarkerZoomLevel for Level05.
Public PropertyZoomLevel06 MarkerZoomLevel Gets the MarkerZoomLevel for Level06.
Public PropertyZoomLevel07 MarkerZoomLevel Gets the MarkerZoomLevel for Level07.
Public PropertyZoomLevel08 MarkerZoomLevel Gets the MarkerZoomLevel for Level08.
Public PropertyZoomLevel09 MarkerZoomLevel Gets the MarkerZoomLevel for Level09.
Public PropertyZoomLevel10 MarkerZoomLevel Gets the MarkerZoomLevel for Level10.
Public PropertyZoomLevel11 MarkerZoomLevel Gets the MarkerZoomLevel for Level11.
Public PropertyZoomLevel12 MarkerZoomLevel Gets the MarkerZoomLevel for Level12.
Public PropertyZoomLevel13 MarkerZoomLevel Gets the MarkerZoomLevel for Level13.
Public PropertyZoomLevel14 MarkerZoomLevel Gets the MarkerZoomLevel for Level14.
Public PropertyZoomLevel15 MarkerZoomLevel Gets the MarkerZoomLevel for Level15.
Public PropertyZoomLevel16 MarkerZoomLevel Gets the MarkerZoomLevel for Level16.
Public PropertyZoomLevel17 MarkerZoomLevel Gets the MarkerZoomLevel for Level17.
Public PropertyZoomLevel18 MarkerZoomLevel Gets the MarkerZoomLevel for Level18.
Public PropertyZoomLevel19 MarkerZoomLevel Gets the MarkerZoomLevel for Level19.
Public PropertyZoomLevel20 MarkerZoomLevel Gets the MarkerZoomLevel for Level20.
MarkerZoomLevelSet()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
GetZoomLevelForDrawing(Int32)
MarkerZoomLevel<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerZoomLevel –> The MarkerZoomLevel object whose styles will be applies to the markers base on the current zoomlevel that passed in.
currentZoomLevelId Int32<!– System.Int32 –> An int value that indicates which zoomlevel is the current zoomlevel. The int value can only be in 1-20.
<!– ThinkGeo.MapSuite.WpfDesktopEdition.MarkerZoomLevelSet –> Go Back
String<!– System.String –>
Void<!– System.Void –>
CustomZoomLevels
When you add custom zoomlevels to the CustomZoomLevels collection, the default ZoomLevel01-20 will be disabled. The zoomLevels in the CustomZoomLevels are matched with the scales defined in the Map.ZoomLevelScales. For example,CustomZoomLevelsmain_page has the scale that equals to Map.ClientZoomLevelScalesmain_page.
Return Type
Collection<MarkerZoomLevel><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WpfDesktopEdition.MarkerZoomLevel} –>
ZoomLevel01
Return Type
ZoomLevel02
Return Type
ZoomLevel03
Return Type
ZoomLevel04
Return Type
ZoomLevel05
Return Type
ZoomLevel06
Return Type
ZoomLevel07
Return Type
ZoomLevel08
Return Type
ZoomLevel09
Return Type
ZoomLevel10
Return Type
ZoomLevel11
Return Type
ZoomLevel12
Return Type
ZoomLevel13
Return Type
ZoomLevel14
Return Type
ZoomLevel15
Return Type
ZoomLevel16
Return Type
ZoomLevel17
Return Type
ZoomLevel18
Return Type
ZoomLevel19
Return Type
ZoomLevel20
Return Type
thinkgeo.mapsuite.wpfdesktopedition.markerzoomlevelset.1440040136.txt.gz · Last modified: 2015/09/18 03:13 (external edit)
