<!– Class –> Contains important properties and methods of current map object.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments</a>
*System.Object **ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments
![]() | Constructor of MapArguments. |
![]() | Object | Object | |
![]() | Object | ||
![]() | RectangleShape | Gets a snapped extent from the provided extent. | |
![]() | RectangleShape, ZoomSnapDirection | ||
![]() | RectangleShape | Gets a snapped zoom level index from the provided extent. | |
![]() | Double | Gets a snapped zoom level index from the provided scale. | |
![]() | Object | ||
![]() | PointShape | Converts a point from world coordinate to screen coordinate. | |
![]() | Object | ||
![]() | PointShape | Converts a point from screen coordinate to world coordinate. |
![]() | Object | ||
![]() | Object |
![]() | Double | Gets or sets the height of current map object in screen coordinate. | |
![]() | Double | Gets or sets the width of current map object in screen coordinate. | |
![]() | RectangleShape | Gets or sets the extent of current map. | |
![]() | Double | Gets or sets a double value that indicates the current resolution of the map. | |
![]() | Double | Gets or sets a double value that indicates the current scale of the map. | |
![]() | GeographyUnit | Gets or sets the GeographyUnit for the map. | |
![]() | RectangleShape | Gets or sets the max extent of current map. | |
![]() | Double | This property gets and sets a maximum scale when navigating the map. When you keep zooming out, and the target scale is bigger than the maximum scale, the zooming operation will be stopped. | |
![]() | Double | This property gets and sets a minimum scale when navigating the map. When you keep zooming in, and the target scale is smaller than the minimum scale, the zooming operation will be stopped. | |
![]() | Collection<Double> | Gets a collection of double values that determines the zoomlevel scales. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MapArguments.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MapArguments.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#GetSnappedExtent.28RectangleShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#GetSnappedExtent.28RectangleShape.29</a>
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape object that indicates the extent which is snapped. |
extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | An extent to be snapped. |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments –> Go Back
extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | |
zoomSnapDirection | ZoomSnapDirection<!– ThinkGeo.MapSuite.WpfDesktopEdition.ZoomSnapDirection –> |
The extent will automatically snapped a closest scale from the ZoomLevelScale list, and create an extent back with the map's screen width and height.
Int32<!– System.Int32 –> | An integar value that indicates the snapped zoom level index. |
The scale will automatically snapped a closest scale from the ZoomLevelScale list, and create an extent back with the map's screen width and height.
scale | Double<!– System.Double –> | A scale to be snapped. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ToScreenCoordinate.28PointShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ToScreenCoordinate.28PointShape.29</a>
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A point in screen coordinate. |
worldCoordinate | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A point in world coordinate to be converted. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ToString.28.29</a>
String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ToWorldCoordinate.28PointShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ToWorldCoordinate.28PointShape.29</a>
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A point in world coordinate. |
screenCoordinate | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A point in screen coordinate to be converted. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ActualHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ActualHeight</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ActualWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ActualWidth</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#CurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#CurrentExtent</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#CurrentResolution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#CurrentResolution</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#CurrentScale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#CurrentScale</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MapUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MapUnit</a>
Return Type |
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MaxExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MaxExtent</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MaximumScale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MaximumScale</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MinimumScale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#MinimumScale</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ZoomLevelScales” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments#ZoomLevelScales</a>
Return Type |
Collection<Double><!– System.Collections.ObjectModel.Collection{System.Double} –> |
