<!– Class –> Represents key event arguments when interacting with the map object.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments</a>
*System.Object **ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments
KeyEventInteractionArguments | Constructor of KeyEventInteractionArguments class. | ||
KeyEventInteractionArguments | String, Boolean, Boolean, Boolean | This is the constructor of this parameter by passing parameters. |
CurrentExtent | RectangleShape | Gets or sets the current extent used in the MapControl. | |
CurrentScale | Double | Gets or sets the scale in the current status. | |
IsAltKeyPressed | Boolean | Gets a value indicating whether the ALT key was pressed. true if the ALT key was pressed; otherwise, false. | |
IsCtrlKeyPressed | Boolean | Gets a value indicating whether the CTRL key was pressed. true if the CTRL key was pressed; otherwise, false. | |
IsShiftKeyPressed | Boolean | Gets a value indicating whether the SHIFT key was pressed. true if the SHIFT key was pressed; otherwise, false. | |
Key | String | This property gets string indicates the key used in the key events. |
If you use this constructor, you have to set its properties manually before use.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#KeyEventInteractionArguments.28String.2C_Boolean.2C_Boolean.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#KeyEventInteractionArguments.28String.2C_Boolean.2C_Boolean.2C_Boolean.29</a>
| key | String<!– System.String –> | This parameters indicates the key string used in the events. |
| isCtrlKeyPressed | Boolean<!– System.Boolean –> | This parameter indicates the CTRIL key is pressed or not. |
| isShiftKeyPressed | Boolean<!– System.Boolean –> | This parameter indicates the SHIFT key is pressed or not. |
| isAltKeyPressed | Boolean<!– System.Boolean –> | This parameter indicates the ALT key is pressed or not. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#CurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#CurrentExtent</a>
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#CurrentScale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#CurrentScale</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#IsAltKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#IsAltKeyPressed</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#IsCtrlKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#IsCtrlKeyPressed</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#IsShiftKeyPressed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#IsShiftKeyPressed</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
