<!– Class –> This class encapsulates the information and simple method for interative actions.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments</a>
*System.Object **ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments
![]() | Constructor of InteractionArguments class. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object(overriden) | Override the ToString API for object. |
![]() | Object | ||
![]() | Object |
![]() | RectangleShape | Gets or sets the current extent used in the MapControl. | |
![]() | ManipulationDelta | ||
![]() | Int32 | Gets or sets the height for the Map Control. | |
![]() | GeographyUnit | Gets or sets the unit for the Map Control. | |
![]() | Int32 | Gets or sets the with for the Map Control. | |
![]() | MapMouseButton | Gets and sets which button is clicked on the map canvas. | |
![]() | Int32 | Gets or sets the Mouse wheel delta used in the MouseWheel method in InterativeOverlay. | |
![]() | Double | Gets or sets the scale in current status. | |
![]() | Single | Gets or sets the screen X position. | |
![]() | Single | Gets or sets the screen Y position. | |
![]() | Double | Gets or sets the searching tolearance for tracking and editing. | |
![]() | Double | Gets or sets the world X position. | |
![]() | Double | Gets or sets the world Y position. | |
![]() | ZoomLevelSet | Gets or sets the ZoomLevelSet used in the Map Control. |
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ToString.28.29</a>
String<!– System.String –> | Returns a string to mark this instance and easy to read its properties. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#CurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#CurrentExtent</a>
Return Type |
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments –> Go Back
Return Type |
ManipulationDelta<!– System.Windows.Input.ManipulationDelta –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapHeight</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapUnit</a>
Return Type |
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MapWidth</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MouseButton” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MouseButton</a>
Return Type |
MapMouseButton<!– ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseButton –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MouseWheelDelta” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#MouseWheelDelta</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Scale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#Scale</a>
Return Type |
Double<!– System.Double –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ScreenX” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ScreenX</a>
Return Type |
Single<!– System.Single –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ScreenY” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ScreenY</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#SearchingTolerance” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#SearchingTolerance</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#WorldX” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#WorldX</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#WorldY” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#WorldY</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ZoomLevelSet” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractionArguments#ZoomLevelSet</a>
Return Type |
ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
