thinkgeo.mapsuite.wpfdesktopedition.drawingoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
      • ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs
DrawingOverlayEventArgs()
Constructor of DrawingOverlayEventArgs class.
This is the default constructor. If you use this constructor then you need to set the required properties manually.
DrawingOverlayEventArgs(RectangleShape,Boolean)
  • worldExtent
    • Description:This parameter is the extent for drawing an overlay.
  • cancel
    • Description:This parameter indicates whether cancel current drawing process.
WorldExtent
Gets or sets an extent to draw the overlay.
Cancel
Gets or sets a value that determines whether you want to cancel the Overlay from drawing.
thinkgeo.mapsuite.wpfdesktopedition.drawingoverlayeventargs.1442545830.txt.gz · Last modified: 2015/09/18 03:10 by admin
