<!– Class –> This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn. This event allows you to cancel, manipulate the Layer, or draw something with the canvas before the Layer draws.
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs
DrawingOverlayEventArgs | Constructor of DrawingOverlayEventArgs class. | ||
DrawingOverlayEventArgs | RectangleShape, Boolean | Constructor of DrawingOverlayEventArgs class. |
Cancel | Boolean | Gets or sets a value that determines whether you want to cancel the Overlay from drawing. | |
WorldExtent | RectangleShape | Gets or sets an extent to draw the overlay. |
This is the default constructor. If you use this constructor then you need to set the required properties manually.
This constructor allows you to set the Overlay to be drawn, the world extent and the image you are drawing on.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#DrawingOverlayEventArgs.28RectangleShape.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#DrawingOverlayEventArgs.28RectangleShape.2C_Boolean.29</a>
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This parameter is the extent for drawing an overlay. |
| cancel | Boolean<!– System.Boolean –> | This parameter indicates whether cancel current drawing process. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Cancel</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#WorldExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#WorldExtent</a>
