thinkgeo.mapsuite.wpfdesktopedition.currentscalechangingwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs
Provides data for the CurrentScaleChanging event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs
CurrentScaleChangingWpfMapEventArgs()
Initialize an instance of the CurrentScaleChangingEventArgs class.
CurrentScaleChangingWpfMapEventArgs(RectangleShape,Double,Double,GeographyUnit,Single,Single,Boolean)
Initialize an instance of the CurrentScaleChangingEventArgs class by passing the currentScale, mapUnit, mapWidth and mapHeight.
  • currentExtent
    • Description:A RectangleShape indicates current map extent.
  • currentScale
    • Description:A double value indicates current map scale.
  • newScale
    • Description:A double value indicates the new scale needs to zoom to.
  • mapUnit
    • Description:A GeographyUnit indicates current map unit.
  • mapWidth
    • Type:Single
    • Description:A float value indicates current map scrren width.
  • mapHeight
    • Type:Single
    • Description:A float value indicates current map scrren height.
  • cancel
    • Description:A boolean value indicates whether needs to cancel current operation.
CurrentScale
This property specifies the CurrentScale of the CurrentScaleChangingEventArgs.
NewScale
This property specifies the NewScale of the CurrentScaleChangingEventArgs.
MapUnit
This property specifies the MapUnit of the CurrentScaleChangingEventArgs.
MapWidth
This property specifies the MapWidth of the CurrentScaleChangingEventArgs.
  • Type:Single
MapHeight
This property specifies the MapHeight of the CurrentExtentChangedEventArgs.
  • Type:Single
CurrentExtent
This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs.
Cancel
Gets or sets whether the action will be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.currentscalechangingwpfmapeventargs.1442545820.txt.gz · Last modified: 2015/09/18 03:10 (external edit)
