<!– Class –> Provides data for the CurrentScaleChanging event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs
CurrentScaleChangingWpfMapEventArgs | Initialize an instance of the CurrentScaleChangingEventArgs class. | ||
CurrentScaleChangingWpfMapEventArgs | RectangleShape, Double, Double, GeographyUnit, Single, Single, Boolean | Initialize an instance of the CurrentScaleChangingEventArgs class by passing the currentScale, mapUnit, mapWidth and mapHeight. |
Cancel | Boolean | Gets or sets whether the action will be canceled or not. | |
CurrentExtent | RectangleShape | This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs. | |
CurrentScale | Double | This property specifies the CurrentScale of the CurrentScaleChangingEventArgs. | |
MapHeight | Single | This property specifies the MapHeight of the CurrentExtentChangedEventArgs. | |
MapUnit | GeographyUnit | This property specifies the MapUnit of the CurrentScaleChangingEventArgs. | |
MapWidth | Single | This property specifies the MapWidth of the CurrentScaleChangingEventArgs. | |
NewScale | Double | This property specifies the NewScale of the CurrentScaleChangingEventArgs. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28RectangleShape.2C_Double.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentScaleChangingWpfMapEventArgs.28RectangleShape.2C_Double.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.2C_Boolean.29</a>
| currentExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicates current map extent. |
| currentScale | Double<!– System.Double –> | A double value indicates current map scale. |
| newScale | Double<!– System.Double –> | A double value indicates the new scale needs to zoom to. |
| mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | A GeographyUnit indicates current map unit. |
| mapWidth | Single<!– System.Single –> | A float value indicates current map scrren width. |
| mapHeight | Single<!– System.Single –> | A float value indicates current map scrren height. |
| cancel | Boolean<!– System.Boolean –> | A boolean value indicates whether needs to cancel current operation. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Cancel” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#Cancel</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#CurrentExtent</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MapHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MapHeight</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MapUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MapUnit</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MapWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#MapWidth</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#NewScale” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangingWpfMapEventArgs#NewScale</a>
