<!– Class –> Provides data for the CurrentScaleChanged event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs
CurrentScaleChangedWpfMapEventArgs | Initialize an instance of the CurrentScaleChangedEventArgs class. | ||
CurrentScaleChangedWpfMapEventArgs | RectangleShape, Double, GeographyUnit, Single, Single | Initialize an instance of the CurrentScaleChangedEventArgs class by passing the currentScale, mapUnit and mapWidth. |
CurrentExtent | RectangleShape | This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs. | |
CurrentScale | Double | This property specifies the CurrentScale of the CurrentScaleChangedEventArgs. | |
MapHeight | Single | This property specifies the MapHeight of the CurrentExtentChangedEventArgs. | |
MapUnit | GeographyUnit | This property specifies the MapUnit of the CurrentScaleChangedEventArgs. | |
MapWidth | Single | This property specifies the MapWidth of the CurrentScaleChangedEventArgs. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentScaleChangedWpfMapEventArgs.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentScaleChangedWpfMapEventArgs.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentScaleChangedWpfMapEventArgs.28RectangleShape.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentScaleChangedWpfMapEventArgs.28RectangleShape.2C_Double.2C_GeographyUnit.2C_Single.2C_Single.29</a>
| currentExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicates current map extent. |
| currentScale | Double<!– System.Double –> | A double value indicates current map scale. |
| mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | A GeographyUnit value indicates current map unit. |
| mapWidth | Single<!– System.Single –> | A float value indicates current map screen width. |
| mapHeight | Single<!– System.Single –> | A float value indicates current map screen height. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentExtent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#CurrentExtent</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MapHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MapHeight</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MapUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MapUnit</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MapWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentScaleChangedWpfMapEventArgs#MapWidth</a>
