thinkgeo.mapsuite.wpfdesktopedition.currentextentchangingwpfmapeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs
Provides data for the CurrentExtentChanging event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangingWpfMapEventArgs
CurrentExtentChangingWpfMapEventArgs()
Initialize an instance of the CurrentExtentChangingEventArgs class.
CurrentExtentChangingWpfMapEventArgs(RectangleShape,RectangleShape,GeographyUnit,Single,Single,Boolean)
Initialize an instance of the CurrentExtentChangingEventArgs class by passing the currentExtent, mapUnit, mapWidth and mapHeight.
  • currentExtent
    • Description:A RectangleShape indicates current map extent.
  • newExtent
    • Description:A RecangleShape indicates the target extent for map.
  • mapUnit
    • Description:A GeographyUnit value indicates current map unit.
  • mapWidth
    • Type:Single
    • Description:A float value indicates screen width of current map.
  • mapHeight
    • Type:Single
    • Description:A float value indicates screen height of current map.
  • cancel
    • Description:A boolean value indicates whether current operation needs cancel.
CurrentExtent
This property specifies the CurrentExtent of the CurrentExtentChangingEventArgs.
NewExtent
This property specifies the NewExtent of the CurrentExtentChangingEventArgs.
MapUnit
This property specifies the MapUnit of the CurrentExtentChangingEventArgs.
MapWidth
This property specifies the MapWidth of the CurrentExtentChangingEventArgs.
  • Type:Single
MapHeight
This property specifies the MapHeight of the CurrentExtentChangingEventArgs.
  • Type:Single
Cancel
Gets or sets whether the action will be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.currentextentchangingwpfmapeventargs.1442545817.txt.gz · Last modified: 2015/09/18 03:10 by admin
