<!– Class –> Provides data for the CurrentExtentChanged event.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs</a>
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs
![]() | Initialize an instance of the CurrentExtentChangedEventArgs class. | ||
![]() | RectangleShape, GeographyUnit, Single, Single | Initialize an instance of the CurrentExtentChangedEventArgs class by passing the currentExtent, mapUnit, mapWidth and mapHeight. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | RectangleShape | This property specifies the CurrentExtent of the CurrentExtentChangedEventArgs. | |
![]() | Single | This property specifies the MapHeight of the CurrentExtentChangedEventArgs. | |
![]() | GeographyUnit | This property specifies the MapUnit of the CurrentExtentChangedEventArgs. | |
![]() | Single | This property specifies the MapWidth of the CurrentExtentChangedEventArgs. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28RectangleShape.2C_GeographyUnit.2C_Single.2C_Single.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#CurrentExtentChangedWpfMapEventArgs.28RectangleShape.2C_GeographyUnit.2C_Single.2C_Single.29</a>
currentExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicates current map extent. |
mapUnit | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | A GeographyUnit indicates current map unit. |
mapWidth | Single<!– System.Single –> | A float value indicates the screen with of current map. |
mapHeight | Single<!– System.Single –> | A float value indicates the screen height of current map. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#ToString.28.29</a>
String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#firstHeading" class="firstHeading" lang="en"><span dir="auto” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#firstHeading“ class=“firstHeading” lang=“en”><span dir=“auto</a>
Return Type |
<!– ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MapHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MapHeight</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MapUnit” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MapUnit</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MapWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.CurrentExtentChangedWpfMapEventArgs#MapWidth</a>
Return Type |
