<!– Structure –> This structure represents a single point in screen coordinates.
*System.ValueType **ThinkGeo.MapSuite.WindowsPhoneCore.ScreenPoint
ScreenPoint | Double, Double | This constructor allows you to create a screen point by passing in an X & Y. |
Equals | Object | Object(overriden) | This method is an override of the Equals functionality. |
GetHashCode | Object(overriden) | This method is an override of the GetHashCode functionality. | |
ToString | Object(overriden) |
| x | Double<!– System.Double –> | This parameter represents the horizontal value of a screen point. |
| y | Double<!– System.Double –> | This parameter represents the vertical value of a screen point. |
| Boolean<!– System.Boolean –> | This method returns the Equals functionality. |
| obj | Object<!– System.Object –> | This parameter is the object you want to check to see if it is equal to the current instance. |
| Int32<!– System.Int32 –> | This method returns the hash code. |
This property returns the X, or horizontal, value of the screen point.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.ScreenPoint –> Go Back
This property returns the Y, or vertical, value of the screen point.
