thinkgeo.mapsuite.windowsphonecore.openingfeaturesourceeventargs
ThinkGeo.MapSuite.WindowsPhoneCore.OpeningFeatureSourceEventArgs
<!– Class –> This class represents the parameters passed in the OpeningFeatureSource event.
Public MethodOpeningFeatureSourceEventArgs This is the default constructor.
Public MethodGetType Object
Public MethodToString Object
OpeningFeatureSourceEventArgs()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
thinkgeo.mapsuite.windowsphonecore.openingfeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
