thinkgeo.mapsuite.windowsphonecore.openedfeaturesourceeventargs
ThinkGeo.MapSuite.WindowsPhoneCore.OpenedFeatureSourceEventArgs
<!– Class –> This class represents the parameters passed in the OpenedFeatureSource event.
Public MethodOpenedFeatureSourceEventArgs This is the default constructor.
Public MethodGetType Object
Public MethodToString Object
OpenedFeatureSourceEventArgs()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
thinkgeo.mapsuite.windowsphonecore.openedfeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
