<!– Class –> This class is a collection with some methods specialized for dealing with Layers and other spatial classes.
We have added some helpful methods like MoveUp, MoveDown, etc. These help when you are manipulating Layers.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.GeoCollection‹T›
GeoCollection‹T› | This is the default constructor for the class. |
Add | T | GeoCollection<T> | This method adds an item to the collection. |
Add | T | Collection<T> | This method adds an item to the collection. |
Add | String, T | GeoCollection<T> | This method adds an item to the collection by specifying the item and a key. |
Clear | Collection<T> | ||
Contains | String | GeoCollection<T> | This method returns whether an item is in the collection based on the specified key. |
Contains | T | Collection<T> | |
CopyTo | T[], Int32 | Collection<T> | |
GetEnumerator | Collection<T> | ||
GetKeys | GeoCollection<T> | This method returns a collection of the keys in the collection. | |
IndexOf | T | Collection<T> | |
Insert | Int32, String, T | GeoCollection<T> | Inserts an element into the System.Collections.ObjectModel.Collection<T> at the specified index and key. |
Insert | Int32, T | Collection<T> | Inserts an element into the System.Collections.ObjectModel.Collection<T> at the specified index. |
Insert | Int32, T | GeoCollection<T> | Inserts an element into the System.Collections.ObjectModel.Collection<T> at the specified index. |
MoveDown | Int32 | GeoCollection<T> | This method moves an item down in the collection. |
MoveDown | T | GeoCollection<T> | This method moves an item down in the collection. |
MoveDown | String | GeoCollection<T> | This method moves an item down in the collection. |
MoveTo | Int32, Int32 | GeoCollection<T> | This method moves the item at fromIndex to the location of toIndex in the collection. |
MoveTo | String, Int32 | GeoCollection<T> | This method moves the item with the key you specified to the location of toIndex in the collection. |
MoveTo | T, Int32 | GeoCollection<T> | This method moves the item you specified to the location of toIndex in the collection. |
MoveToBottom | T | GeoCollection<T> | This method moves the item specified key to the bottom of the collection. |
MoveToBottom | Int32 | GeoCollection<T> | This method moves the item at the specified index to the bottom of the collection. |
MoveToBottom | String | GeoCollection<T> | This method moves the item with the specified key to the bottom of the collection. |
MoveToTop | Int32 | GeoCollection<T> | This method moves the item at the specified index to the top of the collection. |
MoveToTop | String | GeoCollection<T> | This method moves the item with the specified key to the top of the collection. |
MoveToTop | T | GeoCollection<T> | This method moves the item specified to the top of the collection. |
MoveUp | Int32 | GeoCollection<T> | This method moves an item up in the collection. |
MoveUp | String | GeoCollection<T> | This method moves an item up in the collection. |
MoveUp | T | GeoCollection<T> | This method moves an item up in the collection. |
Remove | T | Collection<T> | |
Remove | String | GeoCollection<T> | This method removes an item from the collection based on the specified key. |
RemoveAt | Int32 | Collection<T> | |
Count | Int32 | Collection<T> | |
Item | T | Collection<T> | |
Item | T | GeoCollection<T> |
Items | IList<T> | Collection<T> |
Added | AddedGeoCollectionEventArgs | GeoCollection<T> | |
Adding | AddingGeoCollectionEventArgs | GeoCollection<T> | |
ClearedItems | ClearedItemsGeoCollectionEventArgs | GeoCollection<T> | |
ClearingItems | ClearingItemsGeoCollectionEventArgs | GeoCollection<T> | |
CollectionChanged | NotifyCollectionChangedEventArgs | GeoCollection<T> | |
Inserted | InsertedGeoCollectionEventArgs | GeoCollection<T> | |
Inserting | InsertingGeoCollectionEventArgs | GeoCollection<T> | |
PropertyChanged | PropertyChangedEventArgs | GeoCollection<T> | |
Removed | RemovedGeoCollectionEventArgs | GeoCollection<T> | |
Removing | RemovingGeoCollectionEventArgs | GeoCollection<T> |
This method adds an item to the collection, and the item's key will be a random GUID.
| item | T<!– T –> | This parameter is the item you want added to the collection. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCollection{T} –> Go Back
<!– Collection{T} –> Go Back
| key | String<!– System.String –> | This parameter is the key to find the item. |
| Boolean<!– System.Boolean –> | This method returns whether an item is in the collection based on the specified key. |
| key | String<!– System.String –> | This parameter is the key of the item you are searching for. |
| item | T<!– T –> |
| array | T[]<!– Tthinkgeo.mapsuite.windowsphonecore.geocollection_t –> | |
| index | Int32<!– System.Int32 –> |
| IEnumerator<T><!– IEnumerator{T} –> |
| Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns a collection of the keys in the collection. |
| item | T<!– T –> |
| index | Int32<!– System.Int32 –> | The zero-based index at which item should be inserted. |
| key | String<!– System.String –> | The key to find the item. |
| item | T<!– T –> | The object to insert. The value can be null for reference types. |
| index | Int32<!– System.Int32 –> | This parameter is the index of the item in the collection. |
| item | T<!– T –> | This parameter is the item you want to move down in the dictionary. |
| key | String<!– System.String –> | This parameter is the key of the item in the dictionary. |
| fromIndex | Int32<!– System.Int32 –> | This parameter is the index of the item you want move from in the collection. |
| toIndex | Int32<!– System.Int32 –> | This parameter is the target index that you want to move the item to in the collection. |
| key | String<!– System.String –> | This parameter is the key of item you want to move in the collection. |
| item | T<!– T –> | This parameter is the item you want to move in the collection. |
| item | T<!– T –> | This parameter is the item you want move to the bottom of the collection. |
| index | Int32<!– System.Int32 –> | This parameter is the index of the item you want move to the bottom of the collection. |
| key | String<!– System.String –> | This parameter is the key of the item you want move to the bottom of the collection. |
| index | Int32<!– System.Int32 –> | This parameter is the index of the item you want move to the top of the collection. |
| key | String<!– System.String –> | This parameter is the key of the item you want move to the top of the collection. |
| item | T<!– T –> | This parameter is the item you want move to the top of the collection. |
| key | String<!– System.String –> | This parameter is the key of the item in the collection. |
| item | T<!– T –> | This parameter is the item you want to move up in the collection. |
| item | T<!– T –> |
| key | String<!– System.String –> | This parameter is the key of the item you want to remove. |
This method clears the items from the collection.
<!– Collection{T}(overriden) –> Go Back
| index | Int32<!– System.Int32 –> | |
| item | T<!– T –> |
| e | AddedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.AddedGeoCollectionEventArgs –> |
| e | AddingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.AddingGeoCollectionEventArgs –> |
| e | ClearedItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.ClearedItemsGeoCollectionEventArgs –> |
| e | ClearingItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.ClearingItemsGeoCollectionEventArgs –> |
| e | NotifyCollectionChangedEventArgs<!– System.Collections.Specialized.NotifyCollectionChangedEventArgs –> |
| e | InsertedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.InsertedGeoCollectionEventArgs –> |
| e | InsertingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.InsertingGeoCollectionEventArgs –> |
| e | PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
| e | RemovedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.RemovedGeoCollectionEventArgs –> |
| e | RemovingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.WindowsPhoneCore.RemovingGeoCollectionEventArgs –> |
This method removes an item from the collection based on the specified index.
| index | Int32<!– System.Int32 –> | This parameter is the index of the item you want to remove. |
This method allows you to set an item based on the index.
| index | Int32<!– System.Int32 –> | This parameter is the index of the item you want to set. |
| item | T<!– T –> | This parameter is the item you want to set. |
| T<!– T –> |
| T<!– T –> |
| IList<T><!– IList{T} –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC WindowsPhoneMapSuiteCore ThinkGeo.MapSuite.WindowsPhoneCore UpdateDocumentation
