<!– Class –> FeatureCache is a cache system used in FeatureSource to speed up the fetching data system.
The FeatureCache system uses the BoundingBox as the “Key” to cache the features. For example, if I first get data for a BoundingBox(BoundingBox1) and cache the features within the BoundingBox, in the future if I want to get the features within another BoundingBox(BoundingBox2) which is within BoundingBox1, I will get the features directly from the FeatureCache instead of from FileSystem or DBSystem.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.FeatureCache
FeatureCache | This is the default constructor that will create a new instance of the FeatureCache. |
Add | RectangleShape, Collection<Feature> | This method will add an item to the FeatureCache system by passing a WorldExtent as “Key” and a collection of features as its corresponding cached features. | |
Clear | This method clears all of the CachedItems in this FeatureCache. | ||
Close | The default implementation is to do nothing. | ||
GetFeatures | RectangleShape | This method returns a Collection of Features cached in the FeatureCache system. All of the returning features are within the BoundingBox and were fetched from FileSystem or DBSystem in a previous operation. | |
IsExtentCached | RectangleShape | This method determines whether the WorldExtent is already cached in the FeatureCache System. | |
Open | The default implementation is to do nothing. | ||
AddCore | RectangleShape, Collection<Feature> | This method will add an item to the FeatureCache system by passing a WorldExtent as “Key” and a collection of features as its corresponding cached features. | |
CloseCore | The default implementation is to do nothing. | ||
GetFeaturesCore | RectangleShape | This method returns a Collection of Features cached in the FeatureCache system. All of the returning features are within the BoundingBox and were fetched from FileSystem or DBSystem in a previous operation. | |
MemberwiseClone | Object | ||
OpenCore | The default implementation is to do nothing. |
IsActive | Boolean | This boolean property sepcifies whether cache system is active or not. |
CachedItems | Dictionary<RectangleShape,Collection<Feature» | This property specifies the Cached dictionary items in the FeatureCache system. |
The cache system is not used by default. If you want to use it, you must set the <strong>IsActive</strong> property to true.
This method is the concrete wrapper for the virtual method AddCore. It will return whatever is returned by the AddCore method. To determine what the default implementation of the abstract AddCore method is, please see the documentation for it.
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | |
| features | Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.FeatureCache –> Go Back
This method is the concrete wrapper for the virtual method CloseCore. It will return whatever is returned by the CloseCore method. To determine what the default implementation of the abstract CloseCore method is, please see the documentation for it.
This method is the concrete wrapper for the virtual method GetFeaturesCore. It will return whatever is returned by the GetBoundingBoxCore method. To determine what the default implementation of the abstract GetBoundingBoxCore method is, please see the documentation for it.
| Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> | This method returns a Collection of Features cached in the FeatureCache system. |
| Boolean<!– System.Boolean –> | True if the specified WorldExtent is already cached. Otherwise, returns false. |
| worldExtent | RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | The target WorldExtent which will be determined as already cached or not. |
This method is the concrete wrapper for the virtual method OpenCore. It will return whatever is returned by the OpenCore method. To determine what the default implementation of the abstract OpenCore method is, please see the documentation for it.
| Dictionary<RectangleShape,Collection<Feature»<!– System.Collections.Generic.Dictionary{ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape,System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature}} –> |
