thinkgeo.mapsuite.windowsphonecore.drawingpenalignment
ThinkGeo.MapSuite.WindowsPhoneCore.DrawingPenAlignment
<!– Enumeration –> Specifies the alignment of a GeoPen object in relation to the theoretical, zero-width line.
Items
Name Summary
Center Specifies that the GeoPen object is centered over the theoretical line.
Inset Specifies that the GeoPen is positioned on the inside of the theoretical line.
Left Specifies the GeoPen is positioned to the left of the theoretical line.
Outset Specifies the GeoPen is positioned on the outside of the theoretical line.
Right Specifies the GeoPen is positioned to the right of the theoretical line.
thinkgeo.mapsuite.windowsphonecore.drawingpenalignment.txt · Last modified: 2017/03/16 21:59 (external edit)
