<!– Enumeration –> This enumeration specifies how to join consecutive line or curve segments.
| Name | Summary |
| Bevel | Specifies a beveled join. This produces a diagonal corner. |
| Miter | Specifies a mitered join. This produces a sharp corner or a clipped corner, depending on whether the length of the miter exceeds the miter limit. |
| MiterClipped | Specifies a mitered join. This produces a sharp corner or a beveled corner, depending on whether the length of the miter exceeds the miter limit. |
| Round | Specifies a circular join. This produces a smooth, circular arc between the lines. |
