<!– Enumeration –> This enumeration represents the available cap styles with which a GeoPen object can end a line.
| Name | Summary |
| Round | This member specifies a round line cap. |
| AnchorMask | This member specifies a mask used to check whether a line cap is an anchor cap. |
| ArrowAnchor | This member specifies an arrow-shaped anchor cap. |
| Custom | This member specifies a custom line cap. |
| DiamondAnchor | This member specifies a diamond anchor cap. |
| Flat | This member specifies a flat line cap. |
| NoAnchor | This member specifies no anchor. |
| RoundAnchor | This member specifies a round anchor cap. |
| Square | This member specifies a square line cap. |
| SquareAnchor | This member specifies a square anchor line cap. |
| Triangle | This member specifies a triangular line cap. |
