<!– Class –> This static class provides a conversion method to go to and from different units.
*System.Object **ThinkGeo.MapSuite.WindowsPhoneCore.Conversion
![]() ConvertMeasureUnits | Double, AreaUnit, AreaUnit | This method converts from one unit of measure to another. | |
![]() ConvertMeasureUnits | Double, DistanceUnit, DistanceUnit | This method converts from one unit of measure to another. | |
<!– static –> This method converts from one unit of measure to another.
This overload handles area units.
| Double<!– System.Double –> | The return area size, represented in the unit specified in the toUnit parameter. |
| amount | Double<!– System.Double –> | The total area size, represented in the unit specified in the fromUnit parameter. |
| fromUnit | AreaUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaUnit –> | The unit of measure for the area in the Amount parameter. |
| toUnit | AreaUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaUnit –> | The unit of measure for the result. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Conversion –> Go Back
This overload handles length units.
| Double<!– System.Double –> | The return length size, represented in the unit specified in the toUnit parameter. |
| amount | Double<!– System.Double –> | The total length size, represented in the unit specified in the fromUnit parameter. |
| fromUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | The unit of measure for the length in the Amount parameter. |
| toUnit | DistanceUnit<!– ThinkGeo.MapSuite.WindowsPhoneCore.DistanceUnit –> | The unit of measure for the result. |
