thinkgeo.mapsuite.windowsphonecore.closedfeaturesourceeventargs
ThinkGeo.MapSuite.WindowsPhoneCore.ClosedFeatureSourceEventArgs
<!– Class –> This class represents the parameters passed in through the ClosedFeatureSource event.
Public MethodClosedFeatureSourceEventArgs This is the default constructor.
Public MethodGetType Object
Public MethodToString Object
ClosedFeatureSourceEventArgs()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
thinkgeo.mapsuite.windowsphonecore.closedfeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
