thinkgeo.mapsuite.windowsphonecore.applyuntilzoomlevel
ThinkGeo.MapSuite.WindowsPhoneCore.ApplyUntilZoomLevel
<!– Enumeration –> This enumeration is used on a ZoomLevel to allow its styles to be applied to other zoom levels.
Items
Name Summary
None Default; the apply-until-zoom-level feature will not be enabled.
Level01 The zoom level's styles will be applied to zoom level 1.
Level02 The zoom level's styles will be applied to zoom level 2.
Level03 The zoom level's styles will be applied to zoom level 3.
Level04 The zoom level's styles will be applied to zoom level 4.
Level05 The zoom level's styles will be applied to zoom level 5.
Level06 The zoom level's styles will be applied to zoom level 6.
Level07 The zoom level's styles will be applied to zoom level 7.
Level08 The zoom level's styles will be applied to zoom level 8.
Level09 The zoom level's styles will be applied to zoom level 9.
Level10 The zoom level's styles will be applied to zoom level 10.
Level11 The zoom level's styles will be applied to zoom level 11.
Level12 The zoom level's styles will be applied to zoom level 12.
Level13 The zoom level's styles will be applied to zoom level 13.
Level14 The zoom level's styles will be applied to zoom level 14.
Level15 The zoom level's styles will be applied to zoom level 15.
Level16 The zoom level's styles will be applied to zoom level 16.
Level17 The zoom level's styles will be applied to zoom level 17.
Level18 The zoom level's styles will be applied to zoom level 18.
Level19 The zoom level's styles will be applied to zoom level 19.
Level20 The zoom level's styles will be applied to zoom level 20.
thinkgeo.mapsuite.windowsphonecore.applyuntilzoomlevel.txt · Last modified: 2017/03/16 21:59 (external edit)
