<!– Class –> This class is used to display data from OpenStreetMap server.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay</a>
*System.Object ThinkGeo.MapSuite.WebEdition.Overlay *ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay
![]() | Initialize an instance of the OpenStreetMapOverlay class. | ||
![]() | String | Initialize an instance of the OpenStreetMapOverlay class. |
![]() | Object | ||
![]() | Object | ||
![]() | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
![]() | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
![]() | String | Overlay | |
![]() | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
![]() | Collection<Uri> | ||
![]() | String | Overlay | Gets the identifier for the overlay to be found. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
![]() | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
![]() | OpenStreetMapType | Gets or sets a value to display which tileset for render OpenStreetMap data. | |
![]() | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
![]() | Single | Overlay | Gets or sets the opacity level of the overlay. |
![]() | Int32 | Gets or sets the height of each tile, if the OpenStreetMapOverlay uses tiling. | |
![]() | Int32 | Gets or sets the width of each tile, if the OpenStreetMapOverlay uses tiling. |
![]() | Boolean | Overlay(overriden) | Don't support auto tick event by default. |
![]() | String | Overlay(overriden) | Gets the type of this overlay which uses for serializing to JSON and parses to a real overlay on the client side. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OpenStreetMapOverlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OpenStreetMapOverlay.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OpenStreetMapOverlay.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OpenStreetMapOverlay.28String.29</a>
id | String<!– System.String –> | The identifier string of the OpenStreetMapOverlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Equals.28Object.29</a>
Return Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#GetType.28.29</a>
Type<!– System.Type –> |
Returns a JSON string which contains the information for creating an overlay at the client side.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#ToJson.28.29</a>
String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Finalize.28.29</a>
Void<!– System.Void –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OnTick.28EventArgs.29</a>
e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Attribution</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#AutoRefreshInterval</a>
Return Type |
TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#CustomServerUris” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#CustomServerUris</a>
Return Type |
Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> |
<!– ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Id</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#IsBaseOverlay</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#IsVisible</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#IsVisibleInOverlaySwitcher</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#MapType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#MapType</a>
Return Type |
OpenStreetMapType<!– ThinkGeo.MapSuite.WebEdition.OpenStreetMapType –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#Name</a>
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type |
Single<!– System.Single –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#TileHeight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#TileHeight</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#TileWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#TileWidth</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#HasTickEvent</a>
Return Type |
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.OpenStreetMapOverlay#OverlayType</a>
Return Type |
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
