thinkgeo.mapsuite.webedition.markervalueitem
ThinkGeo.MapSuite.WebEdition.MarkerValueItem
This class represents one value in a ValueMarkerStyle.
    • ThinkGeo.MapSuite.WebEdition.MarkerValueItem
MarkerValueItem()
Initialize a new instance of the MarkerValueItem class.
MarkerValueItem(String)
Initialize a new instance of the MarkerValueItem class using the value string specified.
  • value
    • Description:The string to compare with the column value of features, which determines whether or not to use this value item to create the markers.
MarkerValueItem(String,MarkerStyle)
Initialize a new instance of the MarkerValueItem class with the value string and custom marker style specified.
It is recommended that you do not use this constructor if it is not necessary. Instead, you can set the properties directly on the DefaultMarkerStyle.
  • value
  • customMarkerStyle
    • Description:The marker style that is applied to the markers with higher priority.
Value
Gets or sets the value that we will use to match with the feature data. If the value matches, we will use the style for this item.
DefaultMarkerStyle
Gets or sets the marker style that will be applied to the markers if the CustomMarkerStyle is not defined.
CustomMarkerStyle
Gets or sets the style that could be any type of MarkerStyle.
The CustomMarkerStyle could be any type of MarkerStyle. This style has a higher priority than the DefaultMarkerStyle. This means that if you defined both DefaultMarkerStyle and CustomMarkerStyle, the CustomMarkerStyle will be used.
thinkgeo.mapsuite.webedition.markervalueitem.1442545718.txt.gz · Last modified: 2015/09/18 03:08 by admin
