Represents a break with a value and style defined.
If you use this default constructor, then you should set the properties manually.
Initialize a new instance of the MarkerClassBreak class using the value specified.
Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined.
Gets or sets the style that could be any type of MarkerStyle.
The CustomMarkerStyle could be any type of MarkerStyle. This style has a higher priority than the DefaultMarkerStyle. This means that if you defined both DefaultMarkerStyle and CustomMarkerStyle, the CustomMarkerStyle will be used.
