thinkgeo.mapsuite.webedition.geokeyedcollection_1
ThinkGeo.MapSuite.WebEdition.GeoKeyedCollection<T>
    • System.Collections.ObjectModel.Collection<T>
      • System.Collections.ObjectModel.KeyedCollection<String,T>
        • ThinkGeo.MapSuite.WebEdition.GeoKeyedCollection<T>
GeoKeyedCollection`1()
  • Initializes a new instance of the GeoKeyedCollection class.
  • For the most updated Info for this topic, please check it here:
GetKeys()
  • Type:Collection<String>
MoveUp(Int32)
  • index
MoveUp(String)
  • key
MoveUp(T)
  • item
    • Type:T
MoveDown(Int32)
  • index
MoveDown(String)
  • key
MoveDown(T)
  • item
    • Type:T
MoveToTop(Int32)
  • index
MoveToTop(String)
  • key
MoveToTop(T)
  • item
    • Type:T
MoveToBottom(Int32)
  • index
MoveToBottom(String)
  • key
MoveToBottom(T)
  • item
    • Type:T
MoveTo(Int32,Int32)
  • fromIndex
  • toIndex
MoveTo(String,Int32)
  • key
  • toIndex
MoveTo(T,Int32)
  • item
    • Type:T
  • toIndex
ToJson()
  • Returns a JSON string that contains information about all of the items in the collection.
  • Description:A string that contains information about all of the items in the collection.
Contains(String)
  • key
Remove(String)
  • key
Add(T)
  • item
    • Type:T
Clear()
CopyTo(T[],Int32)
  • array
    • Type:T[]
  • index
Contains(T)
  • item
    • Type:T
GetEnumerator()
  • Type:IEnumerator<T>
IndexOf(T)
  • item
    • Type:T
Insert(Int32,T)
  • index
  • item
    • Type:T
Remove(T)
  • item
    • Type:T
RemoveAt(Int32)
  • index
GetKeyForItem(T)
  • item
    • Type:T
ChangeItemKey(T,String)
  • item
    • Type:T
  • newKey
ClearItems()
InsertItem(Int32,T)
  • index
  • item
    • Type:T
RemoveItem(Int32)
  • index
SetItem(Int32,T)
  • index
  • item
    • Type:T
Comparer
  • Type:IEqualityComparer<String>
Item
  • Type:T
Count
Item
  • Type:T
Dictionary
  • Type:IDictionary<String,T>
Items
  • Type:IList<T>
thinkgeo.mapsuite.webedition.geokeyedcollection_1.txt · Last modified: 2017/03/16 21:59 (external edit)
