<!– Class –> This class represents a right-click shortcut menu used in the map control.
The ContextMenu class represents a right-click shortcut menu which displays when a user right-clicks on a map or an element of a map. Shortcut menus are typically used to combine different menu items that are useful for the user, given the context of the application.Use the <strong>CssClass</strong> property to customize the appearance of the context menu. The <strong>MenuItems</strong> property holds the items in the context menu.You can set the <strong>Width</strong> of the context menu, and the height of the context menu will be automatically ajusted to fit all of the menu's items.
*System.Object **ThinkGeo.MapSuite.WebEdition.ContextMenu
ContextMenu | Initializes a new instance of the ContextMenu class with no menu items specified. | ||
ContextMenu | String, Int32 | Initializes a new instance of the ContextMenu class with the specified identifier and width. | |
ContextMenu | String, Int32, String | Initializes a new instance of the ContextMenu class with the identifier, width and CSS class string. |
CssClass | String | Gets or sets the CSS class of the context menu. | |
Id | String | Gets the identifier of the ContextMenu object. | |
MenuItems | GeoKeyedCollection<ContextMenuItem> | Gets the menu item collection of the context menu. | |
Width | Int32 | Gets or sets the width of the context menu. |
Initializes a new instance of the ContextMenu class.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28String.2C_Int32.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28String.2C_Int32.29</a>
| id | String<!– System.String –> | The key of the context menu in string format. |
| width | Int32<!– System.Int32 –> | The width of the context menu. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28String.2C_Int32.2C_String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ContextMenu.28String.2C_Int32.2C_String.29</a>
| cssClass | String<!– System.String –> | The CSS class for the context menu. |
Creates a deep copy of this ContextMenu object.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#CloneDeep.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#CloneDeep.28.29</a>
| ContextMenu<!– ThinkGeo.MapSuite.WebEdition.ContextMenu –> | A deep copy of the ContextMenu object. |
<!– ThinkGeo.MapSuite.WebEdition.ContextMenu –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#GetType.28.29</a>
Returns a JSON string that contains information for creating the context menu at the client side.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ToJson.28.29</a>
| String<!– System.String –> | A string for creating the context menu at the client side. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#CssClass” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#CssClass</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Id</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#MenuItems” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#MenuItems</a>
| GeoKeyedCollection<ContextMenuItem><!– ThinkGeo.MapSuite.WebEdition.GeoKeyedCollection{ThinkGeo.MapSuite.WebEdition.ContextMenuItem} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Width” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.ContextMenu#Width</a>
