thinkgeo.mapsuite.webedition.cloudpopup
ThinkGeo.MapSuite.WebEdition.CloudPopup
<!– Class –> Represents the popups that appear in a cloud (a.k.a. balloon) shape.
When you add a &lt;strong&gt;CloudPopup&lt;/strong&gt; object to map, a cloud-shaped popup will be created at the client side.You can put any HTML string in the &lt;strong&gt;ContentHtml&lt;/strong&gt; property, which will be parsed and displayed in the popup.
Public MethodCloudPopup Initialize an instance of the CloudPopup class.
Public MethodCloudPopup String Initialize an instance of the CloudPopup class with an Id string.
Public MethodCloudPopup String, PointShape Initialize an instance of the CloudPopup class with an Id string and the position.
Public MethodCloudPopup String, PointShape, String Initialize an instance of the CloudPopup class with an Id string, position and the content of the popup.
Public MethodCloudPopup String, PointShape, String, Int32, Int32 Initialize an instance of the CloudPopup class with Id string, position, popup content and size.
Public MethodCloudPopup String, PointShape, String, Int32, Int32, Boolean Initialize an instance of the CloudPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.
Public MethodCloudPopup String, PointShape, String, Int32, Int32, Boolean, Boolean Initialize an instance of the CloudPopup class with an Id string, position, popup's content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.
Public MethodCloneShallow Popup Creates a shallow copy of the current popup object.
Public MethodGetType Object
Public MethodToJson Popup Returns a JSON string which contains the popup's information and is used to create the popup at the client side.
Public MethodToString Object
Public PropertyAutoPan Boolean Popup Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed.
Public PropertyAutoSize Boolean Popup Gets or sets a value that indicates whether the popup is automatically resized to fit its contents.
Public PropertyContentHtml String Gets or sets the content HTML of the popup window.
Public PropertyHasCloseButton Boolean Popup Gets or sets a value that indicates whether the popup window has a close button in the upper right corner.
Public PropertyHeight Int32 Popup Gets or sets the height of the popup.
Public PropertyId String Popup Gets the identifier by which you can find the popup.
Public PropertyIsVisible Boolean Popup Gets or sets a value that indicates whether the popup is visible on the map.
Public PropertyOffsetXInPixels Int32 Popup Gets or sets the popup's pixel offset in X direction.
Public PropertyOffsetYInPixels Int32 Popup Gets or sets the popup's pixel offset in Y direction.
Public PropertyOpacity Single Popup Gets or sets the opacity level of the popup.
Public PropertyPosition PointShape Popup Gets or sets a point shape in world coordinates that represents the position of the popup.
Public PropertyWidth Int32 Popup Gets or sets the width of the popup.
Protected PropertyPopupType String Popup(overriden) Gets a string that represents the type of the Popup object.
CloudPopup()
Overloads
Name Type Description
Go Back
CloudPopup(String)
Overloads
id String<!– System.String –> The identifier by which you can find the popup.
Go Back
CloudPopup(String, PointShape)
Overloads
position PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> A point shape in world coordinates that indicates the position of the popup.
Go Back
CloudPopup(String, PointShape, String)
Overloads
contentHtml String<!– System.String –> An HTML string rendered as the popup content.
Go Back
CloudPopup(String, PointShape, String, Int32, Int32)
Overloads
width Int32<!– System.Int32 –> An int value that indicates the popup's width.
height Int32<!– System.Int32 –> An int value that indicates the popup's height.
Go Back
CloudPopup(String, PointShape, String, Int32, Int32, Boolean)
Overloads
autoPan Boolean<!– System.Boolean –> A boolean value indicating whether to pan the map if necessary to show the full popup.
Go Back
CloudPopup(String, PointShape, String, Int32, Int32, Boolean, Boolean)
Overloads
hasCloseButton Boolean<!– System.Boolean –> A boolean value indicating whether the popup should have a close button.
Go Back
CloneShallow()
Return Type Description
Popup<!– ThinkGeo.MapSuite.WebEdition.Popup –>
<!– ThinkGeo.MapSuite.WebEdition.Popup –> Go Back
Type<!– System.Type –>
ToJson()
String<!– System.String –> A string that is used to create the popup at the client side.
Void<!– System.Void –>
AutoPan
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#AutoPan” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#AutoPan</a>
Return Type
AutoSize
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#AutoSize” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#AutoSize</a>
Return Type
ContentHtml
Return Type
<!– ThinkGeo.MapSuite.WebEdition.CloudPopup –> Go Back
HasCloseButton
Return Type
Height
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Height” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Height</a>
Return Type
Id
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Id</a>
Return Type
IsVisible
Return Type
OffsetXInPixels
Return Type
OffsetYInPixels
Return Type
Opacity
The &lt;strong&gt;Opacity&lt;/strong&gt; property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
Return Type
Single<!– System.Single –>
Position
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Position” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Position</a>
Return Type
Width
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Width” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.CloudPopup#Width</a>
Return Type
PopupType
Return Type
<!– ThinkGeo.MapSuite.WebEdition.Popup(overriden) –> Go Back
thinkgeo.mapsuite.webedition.cloudpopup.1440040135.txt.gz · Last modified: 2015/09/18 03:07 (external edit)
