<!– Class –> This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay</a>
AdornmentOverlay | Initialize an instance of the AdornmentOverlay class. | ||
AdornmentOverlay | String | Initialize an instance of the AdornmentOverlay class with the overlay identifier specified. |
Draw | GeoCanvas | Draw all of the layers to the image object using the parameters specified. | |
ToJson | Overlay | Returns a JSON string which contains the information for creating an overlay at the client side. | |
DrawCore | GeoCanvas | This method overrides the DrawCore logic in the Overlay base class. Draw all of the AdornmentLayers to the image object using the parameters specified. | |
MemberwiseClone | Object | ||
OnTick | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
RegisterJavaScriptLibraryCore | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
Attribution | String | Overlay | |
AutoRefreshInterval | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
Id | String | Overlay | Gets the identifier for the overlay to be found. |
IsBaseOverlay | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
IsVisible | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
IsVisibleInOverlaySwitcher | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
Layers | GeoCollection<AdornmentLayer> | This property gets a collection of the AdornmentLayers that are added to the AdornmentOverlay. | |
Name | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
Opacity | Single | Overlay | Gets or sets the opacity level of the overlay. |
HasTickEvent | Boolean | Overlay | Indicates whether the overlay supports tick event. |
OverlayType | String | Overlay(overriden) | Gets a string that indicates the overlay type. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AdornmentOverlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AdornmentOverlay.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AdornmentOverlay.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AdornmentOverlay.28String.29</a>
| id | String<!– System.String –> | The identifier string used to retrieve the overlay for collection. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Draw.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Draw.28GeoCanvas.29</a>
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | This parameter specifies the target canvas to draw the current AdornmentOverlay on. |
<!– ThinkGeo.MapSuite.WebEdition.AdornmentOverlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#ToJson.28.29</a>
| String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#DrawCore.28GeoCanvas.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#DrawCore.28GeoCanvas.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OnTick.28EventArgs.29</a>
| e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
| page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Attribution</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#AutoRefreshInterval</a>
| TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Id</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsBaseOverlay</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsVisible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#IsVisibleInOverlaySwitcher</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Layers” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Layers</a>
| GeoCollection<AdornmentLayer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.AdornmentLayer} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#Name</a>
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#HasTickEvent</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.AdornmentOverlay#OverlayType</a>
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
| Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
