<!– Enumeration –> Specifies the format of the map image.
If the image is laid over other images, use the Png image format which can use transparent background. If you have low bandwidth network, use the Jpeg image format. You can reduce the quality of the Jpeg image and make its size smaller.If the image is laid over other images, use the Png image format which can use transparent background. If you have low bandwidth network, use the Jpeg image format. You can reduce the quality of the Jpeg image and make its size smaller.
| Name | Summary |
| Png | Specifies the image is in the W3C Portable Network Graphics (PNG) image format. |
| Jpeg | Specifies the image is in the Joint Photographic Experts Group (JPEG) image format. |
NOTOC SilverlightMapConnector ThinkGeo.MapSuite.SilverlightEdition
