<!– Class –> Provides data for the VertexRemoved. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.VertexRemovedEditInteractiveOverlayEventArgs
VertexRemovedEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexRemovedEditInteractiveOverlayEventArgs | Feature, Vertex | This is the commonly used constructor. |
AffectedVertexFeature | Feature | This property gets or sets the Feature to be used to remove vertex. | |
RemovedVertex | Vertex | This property gets or sets the vertex removed. |
| Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.VertexRemovedEditInteractiveOverlayEventArgs –> Go Back
| Vertex<!– ThinkGeo.MapSuite.SilverlightCore.Vertex –> |
