<!– Class –> Provides data for the VertexAdding. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.VertexAddingEditInteractiveOverlayEventArgs
VertexAddingEditInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
VertexAddingEditInteractiveOverlayEventArgs | Boolean, Feature, Vertex | This is the commonly used constructor. |
AddingVertex | Vertex | This property gets or sets the vertex to be added. | |
AffectedVertexFeature | Feature | This property gets or sets the Feature to be used to move vertex. | |
Cancel | Boolean | This property gets or sets the action to be canceled or not. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
| affectedVertexFeature | Feature<!– ThinkGeo.MapSuite.SilverlightCore.Feature –> | This parameter specified the affectedVertex feature property. |
| addingVertex | Vertex<!– ThinkGeo.MapSuite.SilverlightCore.Vertex –> | This parameter specified the target vertex to be added. |
<!– ThinkGeo.MapSuite.SilverlightEdition.VertexAddingEditInteractiveOverlayEventArgs –> Go Back
