<!– Class –> Provides data for the TrackStarting. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | Vertex, Boolean | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Boolean | This property gets or sets the action to be canceled or not. | |
![]() | Vertex | This property gets or sets the started vertex when tracking shape action is being to start. |
Name | Type | Description |
startingVertex | Vertex<!– ThinkGeo.MapSuite.SilverlightCore.Vertex –> | This parameter specified the started vertex when tracking shape action is being to start. |
cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs –> Go Back
Return Type |
