<!– Class –> This is a connector and container of XAP file, which could help you to build up a simple WMS server to generate tile images for silverlight NativeServerLayerOverlay.
This class is inherit from System.Web.UI.SilverlightControls which could provides a way to integrate Microsoft Silverlight content in an ASP.NET Web Page, also, it helps you to build up a simple WMS server which could be connect by the NativeWmsServerOverlay in the Silverlight application.This class is inherit from System.Web.UI.SilverlightControls which could provides a way to integrate Microsoft Silverlight content in an ASP.NET Web Page, also, it helps you to build up a simple WMS server which could be connect by the NativeWmsServerOverlay in the Silverlight application.
*System.Object System.Web.UI.Control *System.Web.UI.WebControls.WebControl System.Web.UI.SilverlightControls.Silverlight *ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector
SilverlightMapConnector | This is a constructor of SilverlightMapConnector. |
ApplyStyle | Style | WebControl | |
ApplyStyleSheetSkin | Page | Control | |
CopyBaseAttributes | WebControl | WebControl | |
DataBind | Control | ||
Dispose | Control | ||
FindControl | String | Control | |
Focus | Control | ||
GetRouteUrl | String, RouteValueDictionary | Control | |
GetRouteUrl | String, Object | Control | |
GetRouteUrl | Object | Control | |
GetRouteUrl | RouteValueDictionary | Control | |
GetUniqueIDRelativeTo | Control | Control | |
HasControls | Control | ||
MergeStyle | Style | WebControl | |
RenderBeginTag | HtmlTextWriter | WebControl | |
RenderControl | HtmlTextWriter | Control | |
RenderEndTag | HtmlTextWriter | WebControl | |
ResolveClientUrl | String | Control | |
ResolveUrl | String | Control | |
SetRenderMethodDelegate | RenderMethod | Control | |
SetTraceData | Object, Object | Control | |
SetTraceData | Object, Object, Object | Control | |
AddAttributesToRender | HtmlTextWriter | WebControl(overriden) | |
AddParsedSubObject | Object | Control | |
BeginRenderTracing | TextWriter, Object | Control | |
BuildProfileTree | String, Boolean | Control | |
ClearCachedClientID | Control | ||
ClearChildControlState | Control | ||
ClearChildState | Control | ||
ClearChildViewState | Control | ||
ClearEffectiveClientIDMode | Control | ||
CreateControlCollection | Control | ||
CreateControlStyle | WebControl | ||
DataBind | Boolean | Control | |
DataBindChildren | Control | ||
EndRenderTracing | TextWriter, Object | Control | |
EnsureChildControls | Control | ||
EnsureID | Control | ||
FindControl | String, Int32 | Control | |
GetDesignModeState | Control | ||
GetScriptDescriptors | Silverlight | ||
GetScriptReferences | Silverlight | ||
GetSilverlightParameters | Silverlight | ||
HasEvents | Control | ||
IsLiteralContent | Control | ||
LoadViewState | Object | Control(overriden) | |
MemberwiseClone | Object | ||
OnBubbleEvent | Object, EventArgs | Control | |
OnDataBinding | EventArgs | Control | |
OnLoad | EventArgs | Control(overriden) | Raises the System.Web.UI.Control.OnLoad event. |
OnPreRender | EventArgs | Control(overriden) | Raises the System.Web.UI.Control.PreRender event. |
RaiseBubbleEvent | Object, EventArgs | Control | |
Render | HtmlTextWriter | Control(overriden) | |
RenderContents | HtmlTextWriter | WebControl(overriden) | |
RenderControl | HtmlTextWriter, ControlAdapter | Control | |
ResolveAdapter | Control | ||
SaveViewState | Control(overriden) | ||
SetDesignModeState | IDictionary | Control | |
TrackViewState | Control(overriden) |
AccessKey | String | WebControl | |
AppRelativeTemplateSourceDirectory | String | Control | |
Attributes | AttributeCollection | WebControl | |
AutoUpgrade | Boolean | Silverlight | |
BackColor | Color | WebControl | |
BindingContainer | Control | Control | |
BorderColor | Color | WebControl | |
BorderStyle | BorderStyle | WebControl | |
BorderWidth | Unit | WebControl | |
ClientID | String | Control | |
ClientIDMode | ClientIDMode | Control | |
ControlStyle | Style | WebControl | |
ControlStyleCreated | Boolean | WebControl | |
Controls | ControlCollection | Control | |
CssClass | String | WebControl | |
DataItemContainer | Control | Control | |
DataKeysContainer | Control | Control | |
EnableCacheVisualization | Boolean | Silverlight | |
EnableFrameRateCounter | Boolean | Silverlight | |
EnableGPUAcceleration | Boolean | Silverlight | |
EnableRedrawRegions | Boolean | Silverlight | |
EnableTheming | Boolean | Control(overriden) | |
EnableViewState | Boolean | Control | |
Enabled | Boolean | WebControl | |
Font | FontInfo | WebControl | |
ForeColor | Color | WebControl | |
GeoCanvas | GeoCanvas | ||
HasAttributes | Boolean | WebControl | |
Height | Unit | WebControl | |
HtmlAccess | HtmlAccess | Silverlight | |
InitParameters | String | Silverlight | |
MaxFrameRate | Int32 | Silverlight | |
MinimumVersion | String | Silverlight | |
NamingContainer | Control | Control | |
OnPluginError | String | Silverlight | |
OnPluginFullScreenChanged | String | Silverlight | |
OnPluginLoaded | String | Silverlight | |
OnPluginResized | String | Silverlight | |
OnPluginSourceDownloadComplete | String | Silverlight | |
OnPluginSourceDownloadProgressChanged | String | Silverlight | |
Page | Page | Control | |
Parent | Control | Control | |
PluginBackground | Color | Silverlight | |
PluginNotInstalledTemplate | ITemplate | Silverlight | |
RenderingCompatibility | Version | Control | |
ScaleMode | ScaleMode | Silverlight | |
ScriptType | String | Silverlight | |
ServerLayerOverlays | GeoCollection<ServerLayerOverlay> | This is a GeoKeyedCollection object which contains NativeServerLayerOverlay which is going to render. | |
Site | ISite | Control | |
SkinID | String | Control(overriden) | |
Source | String | Silverlight | |
SplashScreenSource | String | Silverlight | |
Style | CssStyleCollection | WebControl | |
SupportsDisabledAttribute | Boolean | WebControl | |
TabIndex | Int16 | WebControl | |
TemplateControl | TemplateControl | Control | |
ToolTip | String | WebControl | |
UniqueID | String | Control | |
ValidateRequestMode | ValidateRequestMode | Control | |
ViewStateMode | ViewStateMode | Control | |
Visible | Boolean | Control | |
Windowless | Boolean | Silverlight |
Adapter | ControlAdapter | Control | |
ChildControlsCreated | Boolean | Control | |
ClientIDSeparator | Char | Control | |
DefaultScriptType | String | Silverlight | |
Events | EventHandlerList | Control | |
HasChildViewState | Boolean | Control | |
IdSeparator | Char | Control | |
IsTrackingViewState | Boolean | Control | |
LoadViewStateByID | Boolean | Control | |
TagKey | HtmlTextWriterTag | WebControl | |
TagName | String | WebControl | |
ViewState | StateBag | Control | |
ViewStateIgnoresCase | Boolean | Control |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SilverlightMapConnector.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SilverlightMapConnector.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ApplyStyle.28Style.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ApplyStyle.28Style.29</a>
| s | Style<!– System.Web.UI.WebControls.Style –> |
<!– System.Web.UI.WebControls.WebControl –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ApplyStyleSheetSkin.28Page.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ApplyStyleSheetSkin.28Page.29</a>
| page | Page<!– System.Web.UI.Page –> |
<!– System.Web.UI.Control –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CopyBaseAttributes.28WebControl.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CopyBaseAttributes.28WebControl.29</a>
| controlSrc | WebControl<!– System.Web.UI.WebControls.WebControl –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataBind.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataBind.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Dispose.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Dispose.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#FindControl.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#FindControl.28String.29</a>
| Control<!– System.Web.UI.Control –> |
| id | String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Focus.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Focus.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28String.2C_RouteValueDictionary.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28String.2C_RouteValueDictionary.29</a>
| routeName | String<!– System.String –> | |
| routeParameters | RouteValueDictionary<!– System.Web.Routing.RouteValueDictionary –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28String.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28String.2C_Object.29</a>
| routeParameters | Object<!– System.Object –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28RouteValueDictionary.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetRouteUrl.28RouteValueDictionary.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetUniqueIDRelativeTo.28Control.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetUniqueIDRelativeTo.28Control.29</a>
| control | Control<!– System.Web.UI.Control –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasControls.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasControls.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MergeStyle.28Style.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MergeStyle.28Style.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderBeginTag.28HtmlTextWriter.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderBeginTag.28HtmlTextWriter.29</a>
| writer | HtmlTextWriter<!– System.Web.UI.HtmlTextWriter –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderControl.28HtmlTextWriter.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderControl.28HtmlTextWriter.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderEndTag.28HtmlTextWriter.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderEndTag.28HtmlTextWriter.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ResolveClientUrl.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ResolveClientUrl.28String.29</a>
| relativeUrl | String<!– System.String –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ResolveUrl.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ResolveUrl.28String.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetRenderMethodDelegate.28RenderMethod.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetRenderMethodDelegate.28RenderMethod.29</a>
| renderMethod | RenderMethod<!– System.Web.UI.RenderMethod –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetTraceData.28Object.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetTraceData.28Object.2C_Object.29</a>
| traceDataKey | Object<!– System.Object –> | |
| traceDataValue | Object<!– System.Object –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetTraceData.28Object.2C_Object.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetTraceData.28Object.2C_Object.2C_Object.29</a>
| tracedObject | Object<!– System.Object –> | |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AddAttributesToRender.28HtmlTextWriter.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AddAttributesToRender.28HtmlTextWriter.29</a>
<!– System.Web.UI.WebControls.WebControl(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AddParsedSubObject.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AddParsedSubObject.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BeginRenderTracing.28TextWriter.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BeginRenderTracing.28TextWriter.2C_Object.29</a>
| writer | TextWriter<!– System.IO.TextWriter –> | |
| traceObject | Object<!– System.Object –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BuildProfileTree.28String.2C_Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BuildProfileTree.28String.2C_Boolean.29</a>
| parentId | String<!– System.String –> | |
| calcViewState | Boolean<!– System.Boolean –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearCachedClientID.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearCachedClientID.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearChildControlState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearChildControlState.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearChildState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearChildState.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearChildViewState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearChildViewState.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearEffectiveClientIDMode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClearEffectiveClientIDMode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CreateControlCollection.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CreateControlCollection.28.29</a>
| ControlCollection<!– System.Web.UI.ControlCollection –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CreateControlStyle.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CreateControlStyle.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataBind.28Boolean.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataBind.28Boolean.29</a>
| raiseOnDataBinding | Boolean<!– System.Boolean –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataBindChildren.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataBindChildren.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EndRenderTracing.28TextWriter.2C_Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EndRenderTracing.28TextWriter.2C_Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnsureChildControls.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnsureChildControls.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnsureID.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnsureID.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#FindControl.28String.2C_Int32.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#FindControl.28String.2C_Int32.29</a>
| id | String<!– System.String –> | |
| pathOffset | Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetDesignModeState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetDesignModeState.28.29</a>
| IDictionary<!– System.Collections.IDictionary –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetScriptDescriptors.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetScriptDescriptors.28.29</a>
| IEnumerable<ScriptDescriptor><!– System.Collections.Generic.IEnumerable{System.Web.UI.ScriptDescriptor} –> |
<!– System.Web.UI.SilverlightControls.Silverlight –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetScriptReferences.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetScriptReferences.28.29</a>
| IEnumerable<ScriptReference><!– System.Collections.Generic.IEnumerable{System.Web.UI.ScriptReference} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetSilverlightParameters.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GetSilverlightParameters.28.29</a>
| IDictionary<String,String><!– System.Collections.Generic.IDictionary{System.String,System.String} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasEvents.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasEvents.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#IsLiteralContent.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#IsLiteralContent.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#LoadViewState.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#LoadViewState.28Object.29</a>
| savedState | Object<!– System.Object –> |
<!– System.Web.UI.Control(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnBubbleEvent.28Object.2C_EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnBubbleEvent.28Object.2C_EventArgs.29</a>
| source | Object<!– System.Object –> | |
| args | EventArgs<!– System.EventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnDataBinding.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnDataBinding.28EventArgs.29</a>
| e | EventArgs<!– System.EventArgs –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnLoad.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnLoad.28EventArgs.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPreRender.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPreRender.28EventArgs.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RaiseBubbleEvent.28Object.2C_EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RaiseBubbleEvent.28Object.2C_EventArgs.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderContents.28HtmlTextWriter.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderContents.28HtmlTextWriter.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderControl.28HtmlTextWriter.2C_ControlAdapter.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderControl.28HtmlTextWriter.2C_ControlAdapter.29</a>
| writer | HtmlTextWriter<!– System.Web.UI.HtmlTextWriter –> | |
| adapter | ControlAdapter<!– System.Web.UI.Adapters.ControlAdapter –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ResolveAdapter.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ResolveAdapter.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SaveViewState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SaveViewState.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetDesignModeState.28IDictionary.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SetDesignModeState.28IDictionary.29</a>
| data | IDictionary<!– System.Collections.IDictionary –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TrackViewState.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TrackViewState.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AccessKey” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AccessKey</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AppRelativeTemplateSourceDirectory” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AppRelativeTemplateSourceDirectory</a>
| AttributeCollection<!– System.Web.UI.AttributeCollection –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AutoUpgrade” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#AutoUpgrade</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BackColor” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BackColor</a>
| Color<!– System.Drawing.Color –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BindingContainer” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BindingContainer</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BorderColor” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BorderColor</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BorderStyle” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BorderStyle</a>
| BorderStyle<!– System.Web.UI.WebControls.BorderStyle –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BorderWidth” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#BorderWidth</a>
| Unit<!– System.Web.UI.WebControls.Unit –> |
| ClientIDMode<!– System.Web.UI.ClientIDMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ControlStyleCreated” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ControlStyleCreated</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CssClass” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#CssClass</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataItemContainer” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataItemContainer</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataKeysContainer” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DataKeysContainer</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableCacheVisualization” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableCacheVisualization</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableFrameRateCounter” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableFrameRateCounter</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableGPUAcceleration” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableGPUAcceleration</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableRedrawRegions” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableRedrawRegions</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableTheming” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableTheming</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableViewState” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#EnableViewState</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Enabled” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Enabled</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Font” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Font</a>
| FontInfo<!– System.Web.UI.WebControls.FontInfo –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ForeColor” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ForeColor</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GeoCanvas” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#GeoCanvas</a>
| GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasAttributes” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasAttributes</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Height” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Height</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HtmlAccess” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HtmlAccess</a>
| HtmlAccess<!– System.Web.UI.SilverlightControls.HtmlAccess –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#InitParameters” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#InitParameters</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MaxFrameRate” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MaxFrameRate</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MinimumVersion” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#MinimumVersion</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#NamingContainer” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#NamingContainer</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginError” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginError</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginFullScreenChanged” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginFullScreenChanged</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginLoaded” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginLoaded</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginResized” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginResized</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginSourceDownloadComplete” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginSourceDownloadComplete</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginSourceDownloadProgressChanged” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#OnPluginSourceDownloadProgressChanged</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Parent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Parent</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#PluginBackground” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#PluginBackground</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#PluginNotInstalledTemplate” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#PluginNotInstalledTemplate</a>
| ITemplate<!– System.Web.UI.ITemplate –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderingCompatibility” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#RenderingCompatibility</a>
| Version<!– System.Version –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ScaleMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ScaleMode</a>
| ScaleMode<!– System.Web.UI.SilverlightControls.ScaleMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ScriptType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ScriptType</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ServerLayerOverlays” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ServerLayerOverlays</a>
| GeoCollection<ServerLayerOverlay><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.SilverlightEdition.ServerLayerOverlay} –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Site” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Site</a>
| ISite<!– System.ComponentModel.ISite –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SkinID” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SkinID</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SplashScreenSource” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SplashScreenSource</a>
| CssStyleCollection<!– System.Web.UI.CssStyleCollection –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SupportsDisabledAttribute” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#SupportsDisabledAttribute</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TabIndex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TabIndex</a>
| Int16<!– System.Int16 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TemplateControl” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TemplateControl</a>
| TemplateControl<!– System.Web.UI.TemplateControl –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ToolTip” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ToolTip</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ValidateRequestMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ValidateRequestMode</a>
| ValidateRequestMode<!– System.Web.UI.ValidateRequestMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ViewStateMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ViewStateMode</a>
| ViewStateMode<!– System.Web.UI.ViewStateMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Visible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Visible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Windowless” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Windowless</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ChildControlsCreated” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ChildControlsCreated</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClientIDSeparator” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ClientIDSeparator</a>
| Char<!– System.Char –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DefaultScriptType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#DefaultScriptType</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Public_Events” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Public_Events</a>
| EventHandlerList<!– System.ComponentModel.EventHandlerList –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasChildViewState” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#HasChildViewState</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#IdSeparator” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#IdSeparator</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#IsTrackingViewState” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#IsTrackingViewState</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#LoadViewStateByID” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#LoadViewStateByID</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TagKey” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TagKey</a>
| HtmlTextWriterTag<!– System.Web.UI.HtmlTextWriterTag –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TagName” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#TagName</a>
| StateBag<!– System.Web.UI.StateBag –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ViewStateIgnoresCase” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#ViewStateIgnoresCase</a>
| Event Arguments |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Disposed” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Disposed</a>
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Unload” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.SilverlightEdition.SilverlightMapConnector#Unload</a>
| Event Arguments |
NOTOC SilverlightMapConnector ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
