<!– Class –> This class represents the panning and zooming panel in the upper left corner of the map.
The PanZoomBar map tool consists of a panning control, two zooming buttons and a zoomlevel bar. The panning controls could pan the world map to any angle when mouse down the panning control. The zoomlevel bar represents the zoomlevels of the map (20 zoomlevels altogether). There is a slider on the zoomlevel bar that indicates the map's current zoomlevel. By moving the slider, you can change the map to a different zoomlevel. This map tool is enabled by default.
*System.Object System.Windows.DependencyObject *System.Windows.UIElement System.Windows.FrameworkElement *System.Windows.Controls.Control ThinkGeo.MapSuite.SilverlightEdition.MapTool *ThinkGeo.MapSuite.SilverlightEdition.PanZoomBarMapTool
PanZoomBarMapTool | This is the constructor of the PanZoomBarMapTool class. | ||
PanZoomBarMapTool | Map, Boolean | This is the constructor of the PanZoomBarMapTool class. |
AddHandler | RoutedEvent, Delegate, Boolean | UIElement | |
ApplyTemplate | Control | ||
Arrange | Rect | UIElement | |
CaptureMouse | UIElement | ||
CheckAccess | DependencyObject | ||
ClearValue | DependencyProperty | DependencyObject | |
FindName | String | FrameworkElement | |
Focus | Control | ||
GetAnimationBaseValue | DependencyProperty | DependencyObject | |
GetBindingExpression | DependencyProperty | FrameworkElement | |
GetValue | DependencyProperty | DependencyObject | |
InvalidateArrange | UIElement | ||
InvalidateMeasure | UIElement | ||
Measure | Size | UIElement | |
OnApplyTemplate | FrameworkElement(overriden) | When overridden in a derived class, is invoked whenever application code or internal processes (such as a rebuilding layout pass) call System.Windows.Controls.Control.ApplyTemplate(). | |
ReadLocalValue | DependencyProperty | DependencyObject | |
Refresh | This method sychronizes the drag slice to current zoomlevel. | ||
ReleaseMouseCapture | UIElement | ||
RemoveHandler | RoutedEvent, Delegate | UIElement | |
SetBinding | DependencyProperty, Binding | FrameworkElement | |
SetValue | DependencyProperty, Object | DependencyObject | |
ToString | Object | ||
TransformToVisual | UIElement | UIElement | |
UpdateLayout | UIElement |
ArrangeOverride | Size | FrameworkElement | |
EnabledChangedCore | Boolean | MapTool(overriden) | When overridden in a derived class, is invoked whenever application code or internal processes (such as a rebuilding layout pass) call System.Windows.Controls.Control.ApplyTemplate(). |
GetTemplateChild | String | Control | |
MeasureOverride | Size | FrameworkElement | |
MemberwiseClone | Object | ||
OnCreateAutomationPeer | UIElement | ||
OnGotFocus | RoutedEventArgs | Control | |
OnKeyDown | KeyEventArgs | Control | |
OnKeyUp | KeyEventArgs | Control | |
OnLostFocus | RoutedEventArgs | Control | |
OnLostMouseCapture | MouseEventArgs | Control | |
OnMouseEnter | MouseEventArgs | Control | |
OnMouseLeave | MouseEventArgs | Control | |
OnMouseLeftButtonDown | MouseButtonEventArgs | Control | |
OnMouseLeftButtonUp | MouseButtonEventArgs | Control | |
OnMouseMove | MouseEventArgs | Control | |
OnMouseWheel | MouseWheelEventArgs | Control |
ActualHeight | Double | FrameworkElement | |
ActualWidth | Double | FrameworkElement | |
Background | Brush | Control | |
BorderBrush | Brush | Control | |
BorderThickness | Thickness | Control | |
CacheMode | CacheMode | UIElement | |
Clip | Geometry | UIElement | |
Cursor | Cursor | FrameworkElement | |
DataContext | Object | FrameworkElement | |
DesiredSize | Size | UIElement | |
Dispatcher | Dispatcher | DependencyObject | |
Effect | Effect | UIElement | |
FontFamily | FontFamily | Control | |
FontSize | Double | Control | |
FontStretch | FontStretch | Control | |
FontStyle | FontStyle | Control | |
FontWeight | FontWeight | Control | |
Foreground | Brush | Control | |
HorizontalAlignment | HorizontalAlignment | FrameworkElement | |
HorizontalContentAlignment | HorizontalAlignment | Control | |
IsEnabled | Boolean | MapTool | Gets or sets a value that turns this map tool on or off. |
IsHitTestVisible | Boolean | UIElement | |
IsTabStop | Boolean | Control | |
Language | XmlLanguage | FrameworkElement | |
Margin | Thickness | FrameworkElement | |
MaxHeight | Double | FrameworkElement | |
MaxWidth | Double | FrameworkElement | |
MinHeight | Double | FrameworkElement | |
MinWidth | Double | FrameworkElement | |
Opacity | Double | UIElement | |
OpacityMask | Brush | UIElement | |
Padding | Thickness | Control | |
Parent | DependencyObject | FrameworkElement | |
Projection | Projection | UIElement | |
RenderSize | Size | UIElement | |
RenderTransform | Transform | UIElement | |
RenderTransformOrigin | Point | UIElement | |
Resources | ResourceDictionary | FrameworkElement | |
Style | Style | FrameworkElement | |
TabIndex | Int32 | Control | |
TabNavigation | KeyboardNavigationMode | Control | |
Tag | Object | FrameworkElement | |
Template | ControlTemplate | Control | |
Triggers | TriggerCollection | FrameworkElement | |
UseLayoutRounding | Boolean | UIElement | |
VerticalAlignment | VerticalAlignment | FrameworkElement | |
VerticalContentAlignment | VerticalAlignment | Control | |
Visibility | Visibility | UIElement | |
DefaultStyleKey | Object | Control | |
Map | Map | MapTool | Gets or sets current map that the mapTool will be drawn on |
BindingValidationError | ValidationErrorEventArgs | FrameworkElement | |
GotFocus | RoutedEventArgs | UIElement | |
IsEnabledChanged | DependencyPropertyChangedEventArgs | Control | |
KeyDown | KeyEventArgs | UIElement | |
KeyUp | KeyEventArgs | UIElement | |
LayoutUpdated | EventArgs | FrameworkElement | |
Loaded | RoutedEventArgs | FrameworkElement | |
LostFocus | RoutedEventArgs | UIElement | |
LostMouseCapture | MouseEventArgs | UIElement | |
MouseEnter | MouseEventArgs | UIElement | |
MouseLeave | MouseEventArgs | UIElement | |
MouseLeftButtonDown | MouseButtonEventArgs | UIElement | |
MouseLeftButtonUp | MouseButtonEventArgs | UIElement | |
MouseMove | MouseEventArgs | UIElement | |
MouseWheel | MouseWheelEventArgs | UIElement | |
SizeChanged | SizeChangedEventArgs | FrameworkElement |
This is the constructor of the <strong>PanZoomBarMapTool</strong> class.
| map | Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –> | A Map value indicating where this map tool will be appended on. |
| isEnabled | Boolean<!– System.Boolean –> | A boolean value indicating whether this map tool is enabled or not. |
| routedEvent | RoutedEvent<!– System.Windows.RoutedEvent –> | |
| handler | Delegate<!– System.Delegate –> | |
| handledEventsToo | Boolean<!– System.Boolean –> |
<!– System.Windows.UIElement –> Go Back
<!– System.Windows.Controls.Control –> Go Back
| finalRect | Rect<!– System.Windows.Rect –> |
<!– System.Windows.DependencyObject –> Go Back
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> |
| name | String<!– System.String –> |
<!– System.Windows.FrameworkElement –> Go Back
| BindingExpression<!– System.Windows.Data.BindingExpression –> |
| availableSize | Size<!– System.Windows.Size –> |
<!– System.Windows.FrameworkElement(overriden) –> Go Back
<!– ThinkGeo.MapSuite.SilverlightEdition.PanZoomBarMapTool –> Go Back
| BindingExpressionBase<!– System.Windows.Data.BindingExpressionBase –> |
| dp | DependencyProperty<!– System.Windows.DependencyProperty –> | |
| binding | Binding<!– System.Windows.Data.Binding –> |
| value | Object<!– System.Object –> |
| GeneralTransform<!– System.Windows.Media.GeneralTransform –> |
| visual | UIElement<!– System.Windows.UIElement –> |
| finalSize | Size<!– System.Windows.Size –> |
| newValue | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTool(overriden) –> Go Back
| DependencyObject<!– System.Windows.DependencyObject –> |
| childName | String<!– System.String –> |
| AutomationPeer<!– System.Windows.Automation.Peers.AutomationPeer –> |
| e | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> |
| e | KeyEventArgs<!– System.Windows.Input.KeyEventArgs –> |
| e | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> |
| e | MouseButtonEventArgs<!– System.Windows.Input.MouseButtonEventArgs –> |
| e | MouseWheelEventArgs<!– System.Windows.Input.MouseWheelEventArgs –> |
| Brush<!– System.Windows.Media.Brush –> |
| Thickness<!– System.Windows.Thickness –> |
| CacheMode<!– System.Windows.Media.CacheMode –> |
| Geometry<!– System.Windows.Media.Geometry –> |
| Cursor<!– System.Windows.Input.Cursor –> |
| Dispatcher<!– System.Windows.Threading.Dispatcher –> |
| Effect<!– System.Windows.Media.Effects.Effect –> |
| FontFamily<!– System.Windows.Media.FontFamily –> |
| FontStretch<!– System.Windows.FontStretch –> |
| FontStyle<!– System.Windows.FontStyle –> |
| FontWeight<!– System.Windows.FontWeight –> |
| HorizontalAlignment<!– System.Windows.HorizontalAlignment –> |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTool –> Go Back
| XmlLanguage<!– System.Windows.Markup.XmlLanguage –> |
| Projection<!– System.Windows.Media.Projection –> |
| Transform<!– System.Windows.Media.Transform –> |
| Point<!– System.Windows.Point –> |
| ResourceDictionary<!– System.Windows.ResourceDictionary –> |
| Style<!– System.Windows.Style –> |
| KeyboardNavigationMode<!– System.Windows.Input.KeyboardNavigationMode –> |
| ControlTemplate<!– System.Windows.Controls.ControlTemplate –> |
| TriggerCollection<!– System.Windows.TriggerCollection –> |
| VerticalAlignment<!– System.Windows.VerticalAlignment –> |
| Visibility<!– System.Windows.Visibility –> |
| Event Arguments |
| ValidationErrorEventArgs<!– System.Windows.Controls.ValidationErrorEventArgs –> |
| Event Arguments |
| Event Arguments |
| DependencyPropertyChangedEventArgs<!– System.Windows.DependencyPropertyChangedEventArgs –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| EventArgs<!– System.EventArgs –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| SizeChangedEventArgs<!– System.Windows.SizeChangedEventArgs –> |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
