<!– Class –> This class represents a small icon on the map that is used for marking a point.
*System.Object System.Windows.DependencyObject *System.Windows.UIElement System.Windows.FrameworkElement *System.Windows.Controls.Control **ThinkGeo.MapSuite.SilverlightEdition.Marker
Marker | This is the constructor of the Marker class. | ||
Marker | Double, Double | This is the constructor of the Marker class. | |
Marker | PointShape | This is the constructor of the Marker class. | |
Marker | Point | This is the constructor of the Marker class. |
AddHandler | RoutedEvent, Delegate, Boolean | UIElement | |
ApplyTemplate | Control | ||
Arrange | Rect | UIElement | |
CaptureMouse | UIElement | ||
CheckAccess | DependencyObject | ||
ClearValue | DependencyProperty | DependencyObject | |
FindName | String | FrameworkElement | |
Focus | Control | ||
GetAnimationBaseValue | DependencyProperty | DependencyObject | |
GetBindingExpression | DependencyProperty | FrameworkElement | |
GetValue | DependencyProperty | DependencyObject | |
InvalidateArrange | UIElement | ||
InvalidateMeasure | UIElement | ||
Measure | Size | UIElement | |
OnApplyTemplate | FrameworkElement(overriden) | Builds the visual tree for the GeoPopup control when a new template is applied. | |
ReadLocalValue | DependencyProperty | DependencyObject | |
ReleaseMouseCapture | UIElement | ||
RemoveHandler | RoutedEvent, Delegate | UIElement | |
SetBinding | DependencyProperty, Binding | FrameworkElement | |
SetValue | DependencyProperty, Object | DependencyObject | |
ToString | Object | ||
TransformToVisual | UIElement | UIElement | |
UpdateLayout | UIElement |
ArrangeOverride | Size | FrameworkElement | |
GetTemplateChild | String | Control | |
MeasureOverride | Size | FrameworkElement | |
MemberwiseClone | Object | ||
OnCreateAutomationPeer | UIElement | ||
OnGotFocus | RoutedEventArgs | Control | |
OnKeyDown | KeyEventArgs | Control | |
OnKeyUp | KeyEventArgs | Control | |
OnLostFocus | RoutedEventArgs | Control | |
OnLostMouseCapture | MouseEventArgs | Control | |
OnMouseEnter | MouseEventArgs | Control | |
OnMouseLeave | MouseEventArgs | Control | |
OnMouseLeftButtonDown | MouseButtonEventArgs | Control | |
OnMouseLeftButtonUp | MouseButtonEventArgs | Control | |
OnMouseMove | MouseEventArgs | Control | |
OnMouseWheel | MouseWheelEventArgs | Control |
ActualHeight | Double | FrameworkElement | |
ActualWidth | Double | FrameworkElement | |
Background | Brush | Control | |
BorderBrush | Brush | Control | |
BorderThickness | Thickness | Control | |
CacheMode | CacheMode | UIElement | |
Clip | Geometry | UIElement | |
Cursor | Cursor | FrameworkElement | |
DataContext | Object | FrameworkElement | |
DesiredSize | Size | UIElement | |
Dispatcher | Dispatcher | DependencyObject | |
Effect | Effect | UIElement | |
FontFamily | FontFamily | Control | |
FontSize | Double | Control | |
FontStretch | FontStretch | Control | |
FontStyle | FontStyle | Control | |
FontWeight | FontWeight | Control | |
Foreground | Brush | Control | |
HorizontalAlignment | HorizontalAlignment | FrameworkElement | |
HorizontalContentAlignment | HorizontalAlignment | Control | |
ImageHeight | Double | Gets or sets the height of the marker image. | |
ImageOffsetX | Double | Gets or sets the image's X offset in screen coordinates. | |
ImageOffsetY | Double | Gets or sets the image's Y offset in screen coordinates. | |
ImageRotationAngle | Double | Gets or sets the rotation angle of the marker image by degree. | |
ImageSource | ImageSource | Gets or sets an ImageSource for the marker icon. | |
ImageWidth | Double | Gets or sets the width of the web image. | |
IsEnabled | Boolean | Control | |
IsHitTestVisible | Boolean | UIElement | |
IsTabStop | Boolean | Control | |
Language | XmlLanguage | FrameworkElement | |
Margin | Thickness | FrameworkElement | |
MaxHeight | Double | FrameworkElement | |
MaxWidth | Double | FrameworkElement | |
MinHeight | Double | FrameworkElement | |
MinWidth | Double | FrameworkElement | |
Opacity | Double | UIElement | |
OpacityMask | Brush | UIElement | |
Padding | Thickness | Control | |
Parent | DependencyObject | FrameworkElement | |
Popup | GeoPopup | Gets or sets the shortcut menu associated with the marker. | |
PopupDelay | TimeSpan | Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays. | |
Position | Point | Gets or sets a Point object that represents the current location of the marker. | |
Projection | Projection | UIElement | |
RenderSize | Size | UIElement | |
RenderTransform | Transform | UIElement | |
RenderTransformOrigin | Point | UIElement | |
Resources | ResourceDictionary | FrameworkElement | |
Style | Style | FrameworkElement | |
TabIndex | Int32 | Control | |
TabNavigation | KeyboardNavigationMode | Control | |
Tag | Object | FrameworkElement | |
Template | ControlTemplate | Control | |
Text | String | Gets or sets the text displayed on the image. | |
TextOffsetX | Double | Gets or sets the x offset of text on the marker. | |
TextOffsetY | Double | Gets or sets the y offset of text on the marker. | |
TextRotationAngle | Double | Gets or sets the rotation angle of the marker text by degree. | |
TextWidth | Double | Gets or sets the width of text on the marker. | |
TextWrapping | TextWrapping | Gets or sets whether text is wrapping or not when it reaches the edge of its container. | |
Triggers | TriggerCollection | FrameworkElement | |
UseLayoutRounding | Boolean | UIElement | |
VerticalAlignment | VerticalAlignment | FrameworkElement | |
VerticalContentAlignment | VerticalAlignment | Control | |
Visibility | Visibility | UIElement | |
DefaultStyleKey | Object | Control |
BindingValidationError | ValidationErrorEventArgs | FrameworkElement | |
GotFocus | RoutedEventArgs | UIElement | |
IsEnabledChanged | DependencyPropertyChangedEventArgs | Control | |
KeyDown | KeyEventArgs | UIElement | |
KeyUp | KeyEventArgs | UIElement | |
LayoutUpdated | EventArgs | FrameworkElement | |
Loaded | RoutedEventArgs | FrameworkElement | |
LostFocus | RoutedEventArgs | UIElement | |
LostMouseCapture | MouseEventArgs | UIElement | |
MouseEnter | MouseEventArgs | UIElement | |
MouseLeave | MouseEventArgs | UIElement | |
MouseLeftButtonDown | MouseButtonEventArgs | UIElement | |
MouseLeftButtonUp | MouseButtonEventArgs | UIElement | |
MouseMove | MouseEventArgs | UIElement | |
MouseWheel | MouseWheelEventArgs | UIElement | |
SizeChanged | SizeChangedEventArgs | FrameworkElement |
This is the constructor of the <strong>Marker</strong> class.
Name | Type | Description |
worldX | Double<!– System.Double –> | A double value indicating the world x coordinate of the Marker |
worldY | Double<!– System.Double –> | A double value indicating the world y coordinate of the Marker |
position | PointShape<!– ThinkGeo.MapSuite.SilverlightCore.PointShape –> | A PointShape that specifies the position of the Marker |
position | Point<!– System.Windows.Point –> | A Point that specifies the position of the Marker |
Return Type | Description |
Void<!– System.Void –> |
routedEvent | RoutedEvent<!– System.Windows.RoutedEvent –> | |
handler | Delegate<!– System.Delegate –> | |
handledEventsToo | Boolean<!– System.Boolean –> |
<!– System.Windows.UIElement –> Go Back
<!– System.Windows.Controls.Control –> Go Back
finalRect | Rect<!– System.Windows.Rect –> |
<!– System.Windows.DependencyObject –> Go Back
dp | DependencyProperty<!– System.Windows.DependencyProperty –> |
name | String<!– System.String –> |
<!– System.Windows.FrameworkElement –> Go Back
BindingExpression<!– System.Windows.Data.BindingExpression –> |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
availableSize | Size<!– System.Windows.Size –> |
<!– System.Windows.FrameworkElement(overriden) –> Go Back
BindingExpressionBase<!– System.Windows.Data.BindingExpressionBase –> |
dp | DependencyProperty<!– System.Windows.DependencyProperty –> | |
binding | Binding<!– System.Windows.Data.Binding –> |
value | Object<!– System.Object –> |
GeneralTransform<!– System.Windows.Media.GeneralTransform –> |
visual | UIElement<!– System.Windows.UIElement –> |
finalSize | Size<!– System.Windows.Size –> |
DependencyObject<!– System.Windows.DependencyObject –> |
childName | String<!– System.String –> |
AutomationPeer<!– System.Windows.Automation.Peers.AutomationPeer –> |
e | RoutedEventArgs<!– System.Windows.RoutedEventArgs –> |
e | KeyEventArgs<!– System.Windows.Input.KeyEventArgs –> |
e | MouseEventArgs<!– System.Windows.Input.MouseEventArgs –> |
e | MouseButtonEventArgs<!– System.Windows.Input.MouseButtonEventArgs –> |
e | MouseWheelEventArgs<!– System.Windows.Input.MouseWheelEventArgs –> |
Return Type |
Return Type |
Return Type |
Brush<!– System.Windows.Media.Brush –> |
Return Type |
Return Type |
Thickness<!– System.Windows.Thickness –> |
Return Type |
CacheMode<!– System.Windows.Media.CacheMode –> |
Return Type |
Geometry<!– System.Windows.Media.Geometry –> |
Return Type |
Cursor<!– System.Windows.Input.Cursor –> |
Return Type |
Return Type |
Return Type |
Dispatcher<!– System.Windows.Threading.Dispatcher –> |
Return Type |
Effect<!– System.Windows.Media.Effects.Effect –> |
Return Type |
FontFamily<!– System.Windows.Media.FontFamily –> |
Return Type |
Return Type |
FontStretch<!– System.Windows.FontStretch –> |
Return Type |
FontStyle<!– System.Windows.FontStyle –> |
Return Type |
FontWeight<!– System.Windows.FontWeight –> |
Return Type |
Return Type |
Return Type |
HorizontalAlignment<!– System.Windows.HorizontalAlignment –> |
Return Type |
Return Type |
<!– ThinkGeo.MapSuite.SilverlightEdition.Marker –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
ImageSource<!– System.Windows.Media.ImageSource –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
XmlLanguage<!– System.Windows.Markup.XmlLanguage –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
GeoPopup<!– ThinkGeo.MapSuite.SilverlightEdition.GeoPopup –> |
Return Type |
TimeSpan<!– System.TimeSpan –> |
Return Type |
Return Type |
Projection<!– System.Windows.Media.Projection –> |
Return Type |
Return Type |
Transform<!– System.Windows.Media.Transform –> |
Return Type |
Return Type |
ResourceDictionary<!– System.Windows.ResourceDictionary –> |
Return Type |
Style<!– System.Windows.Style –> |
Return Type |
Return Type |
KeyboardNavigationMode<!– System.Windows.Input.KeyboardNavigationMode –> |
Return Type |
Return Type |
ControlTemplate<!– System.Windows.Controls.ControlTemplate –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
TextWrapping<!– System.Windows.TextWrapping –> |
Return Type |
TriggerCollection<!– System.Windows.TriggerCollection –> |
Return Type |
Return Type |
VerticalAlignment<!– System.Windows.VerticalAlignment –> |
Return Type |
Return Type |
Visibility<!– System.Windows.Visibility –> |
Return Type |
Return Type |
Event Arguments |
ValidationErrorEventArgs<!– System.Windows.Controls.ValidationErrorEventArgs –> |
Event Arguments |
Event Arguments |
DependencyPropertyChangedEventArgs<!– System.Windows.DependencyPropertyChangedEventArgs –> |
Event Arguments |
Event Arguments |
Event Arguments |
EventArgs<!– System.EventArgs –> |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
SizeChangedEventArgs<!– System.Windows.SizeChangedEventArgs –> |
NOTOC SilverlightEdition ThinkGeo.MapSuite.SilverlightEdition UpdateDocumentation
