thinkgeo.mapsuite.silverlightedition.maptools
ThinkGeo.MapSuite.SilverlightEdition.MapTools
<!– Class –> Contains the different map tools as properties and act as an entrance for setting these map controls.
This class is designed just for easy to use. It contains all the available map tools of the map. You can find and set those map tools easily by using this class.
Public MethodMapTools Map Initialize an instance of the MapTools class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyLogo LogoMapTool Gets a LogoMapTool object for setting
Public PropertyMouseCoordinate MouseCoordinateMapTool Gets an MouseCoordinateMapTool object for setting.
Public PropertyMouseMapTool MouseMapTool Gets a MouseMapTool object for setting.
Public PropertyOverlaySwitcher OverlaySwitcherMapTool
Public PropertyPanZoomBar PanZoomBarMapTool Gets an PanZoomBar object for setting.
Public PropertyScaleLine ScaleLineMapTool Gets a ScaleLineMapTool object for setting.
MapTools(Map)
Name Type Description
map Map<!– ThinkGeo.MapSuite.SilverlightEdition.Map –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
Return Type
LogoMapTool<!– ThinkGeo.MapSuite.SilverlightEdition.LogoMapTool –>
<!– ThinkGeo.MapSuite.SilverlightEdition.MapTools –> Go Back
MouseCoordinate
Return Type
MouseCoordinateMapTool<!– ThinkGeo.MapSuite.SilverlightEdition.MouseCoordinateMapTool –>
MouseMapTool
Return Type
MouseMapTool<!– ThinkGeo.MapSuite.SilverlightEdition.MouseMapTool –>
OverlaySwitcher
Return Type
OverlaySwitcherMapTool<!– ThinkGeo.MapSuite.SilverlightEdition.OverlaySwitcherMapTool –>
PanZoomBar
Return Type
PanZoomBarMapTool<!– ThinkGeo.MapSuite.SilverlightEdition.PanZoomBarMapTool –>
ScaleLine
Return Type
ScaleLineMapTool<!– ThinkGeo.MapSuite.SilverlightEdition.ScaleLineMapTool –>
thinkgeo.mapsuite.silverlightedition.maptools.1440040134.txt.gz · Last modified: 2015/09/21 03:28 (external edit)
