<!– Class –> Provides data for the MapMouseWheel event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs
![]() | This is the default constructor of this parameter. | ||
![]() | InteractionArguments | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | InteractionArguments | This property gets the interaction auguments for the event args. |
Name | Type | Description |
interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments –> | This parameter specified the interaction auguments to construct the class. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs –> Go Back
