thinkgeo.mapsuite.silverlightedition.logomaptool
ThinkGeo.MapSuite.SilverlightEdition.LogoMapTool
This class represents an company logo image that displays at the lower-right corner of the map.
    • System.Windows.DependencyObject
      • System.Windows.UIElement
        • System.Windows.FrameworkElement
          • System.Windows.Controls.Control
            • ThinkGeo.MapSuite.SilverlightEdition.MapTool
              • ThinkGeo.MapSuite.SilverlightEdition.LogoMapTool
LogoMapTool()
This is the constructor of the LogoMapTool class.
LogoMapTool(Map)
This is the constructor of the MouseMapTool class.
  • map
    • Type:Map
    • Description:A Map value indicating where the MouseMapTool will be append on.
LogoMapTool(Map,Boolean)
  • map
    • Type:Map
  • isEnabled
    • Description:A boolean value indicates whether this map tool is on or off.
OnApplyTemplate()
Builds the visual tree for the LogoMapTool control when a new template is applied.
Focus()
ApplyTemplate()
FindName(String)
  • name
SetBinding(DependencyProperty,Binding)
  • Type:BindingExpressionBase
  • dp
    • Type:DependencyProperty
  • binding
    • Type:Binding
GetBindingExpression(DependencyProperty)
  • dp
AddHandler(RoutedEvent,Delegate,Boolean)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
TransformToVisual(UIElement)
  • Type:GeneralTransform
  • visual
    • Type:UIElement
Measure(Size)
  • availableSize
    • Type:Size
Arrange(Rect)
  • finalRect
    • Type:Rect
CaptureMouse()
ReleaseMouseCapture()
InvalidateMeasure()
InvalidateArrange()
UpdateLayout()
CheckAccess()
SetValue(DependencyProperty,Object)
  • dp
  • value
ClearValue(DependencyProperty)
  • dp
ReadLocalValue(DependencyProperty)
  • dp
GetAnimationBaseValue(DependencyProperty)
  • dp
GetValue(DependencyProperty)
  • dp
EnabledChangedCore(Boolean)
Occcurs when the Enabled property changes
  • newValue
    • Description:Indicates whether the visibility of MapTool is set as Visibility.Visible
OnDrop(DragEventArgs)
  • e
    • Type:DragEventArgs
NativeMouseMove(MouseEventArgs)
  • e
    • Type:MouseEventArgs
NativeMouseEnter(MouseEventArgs)
  • e
NativeMouseLeave(MouseEventArgs)
  • e
NativeMouseLeftButtonDown(MouseButtonEventArgs)
  • e
    • Type:MouseButtonEventArgs
NativeMouseLeftButtonUp(MouseButtonEventArgs)
  • e
NativeMouseRightButtonDown(MouseButtonEventArgs)
  • e
NativeMouseRightButtonUp(MouseButtonEventArgs)
  • e
NativeMouseWheel(MouseWheelEventArgs)
  • e
    • Type:MouseWheelEventArgs
NativeKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
NativeKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
NativeGotFocus(RoutedEventArgs)
  • e
    • Type:RoutedEventArgs
NativeLostFocus(RoutedEventArgs)
  • e
NativeIsEnabledChanged(IsEnabledChangedEventArgs)
  • e
    • Type:IsEnabledChangedEventArgs
GetValueFromBuiltInStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
NativeOnLostMouseCapture(MouseEventArgs)
  • e
NativeTextInput(TextCompositionEventArgs)
  • e
    • Type:TextCompositionEventArgs
NativeTextInputStart(TextCompositionEventArgs)
  • e
NativeTextInputUpdate(TextCompositionEventArgs)
  • e
NativeDragEnter(DragEventArgs)
  • e
NativeDragLeave(DragEventArgs)
  • e
NativeDragOver(DragEventArgs)
  • e
NativeDrop(DragEventArgs)
  • e
ShowValidationError()
HideValidationError()
UpdateValidationState()
OnManipulationStarted(ManipulationStartedEventArgs)
  • e
    • Type:ManipulationStartedEventArgs
OnManipulationDelta(ManipulationDeltaEventArgs)
  • e
    • Type:ManipulationDeltaEventArgs
OnManipulationCompleted(ManipulationCompletedEventArgs)
  • e
    • Type:ManipulationCompletedEventArgs
OnTap(GestureEventArgs)
  • e
    • Type:GestureEventArgs
OnDoubleTap(GestureEventArgs)
  • e
OnHold(GestureEventArgs)
  • e
GetTemplateChild(String)
  • Type:DependencyObject
  • childName
RemoveTemplateBinding(FrameworkElement,DependencyProperty)
  • target
    • Type:FrameworkElement
  • targetProperty
GoToState(Boolean,String)
  • useTransitions
  • stateName
OnMouseMove(MouseEventArgs)
  • e
OnMouseEnter(MouseEventArgs)
  • e
OnMouseLeave(MouseEventArgs)
  • e
OnMouseLeftButtonDown(MouseButtonEventArgs)
  • e
OnMouseLeftButtonUp(MouseButtonEventArgs)
  • e
OnMouseRightButtonDown(MouseButtonEventArgs)
  • e
OnMouseRightButtonUp(MouseButtonEventArgs)
  • e
OnMouseWheel(MouseWheelEventArgs)
  • e
OnKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnGotFocus(RoutedEventArgs)
  • e
OnLostFocus(RoutedEventArgs)
  • e
OnIsEnabledChanged(IsEnabledChangedEventArgs)
  • e
  • e
OnTextInput(TextCompositionEventArgs)
  • e
OnTextInputStart(TextCompositionEventArgs)
  • e
OnTextInputUpdate(TextCompositionEventArgs)
  • e
OnDragEnter(DragEventArgs)
  • e
OnDragLeave(DragEventArgs)
  • e
OnDragOver(DragEventArgs)
  • e
ApplyTemplateInternal()
GetValueInternal(DependencyProperty)
  • dp
MeasureOverride(Size)
  • Type:Size
  • availableSize
    • Type:Size
ArrangeOverride(Size)
  • Type:Size
  • finalSize
    • Type:Size
OnTreeParentUpdated(DependencyObject,Boolean)
  • newParent
  • bIsNewParentAlive
NotifyDataContextChanged(DataContextChangedEventArgs)
  • e
    • Type:DataContextChangedEventArgs
OnBindingValidationError(ValidationErrorEventArgs)
  • args
    • Type:ValidationErrorEventArgs
CalculateBubblePath()
  • Type:List<FrameworkElement>
RaiseBindingValidationError(ValidationErrorEventArgs)
  • args
OnSizeChanged(Object,SizeChangedEventArgs)
  • sender
  • e
    • Type:SizeChangedEventArgs
OnAncestorDataContextChanged(DataContextChangedEventArgs)
  • e
IsDataContextChangeRelevant(DataContextChangedEventArgs)
  • e
OnDataContextChanged(DataContextChangedEventArgs)
  • e
OnPropertyChanged(DependencyProperty)
  • dp
GetValueFromStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
HasFocus()
FindNameInPage(String,Boolean)
  • name
  • calledFromUserControl
GetPlainText()
HitTest(Point)
  • Type:IEnumerable<UIElement>
  • point
    • Type:Point
HitTest(Rect)
  • rect
    • Type:Rect
IsAncestorOf(UIElement)
  • element
    • Type:UIElement
OnCreateAutomationPeer()
  • Type:AutomationPeer
GetOrCreateAutomationPeer()
GetAutomationPeer()
InvalidateAutomationPeer()
GetChildrenCount()
GetChild(Int32)
  • Type:UIElement
  • childIndex
BringIntoView()
BringIntoView(Rect)
  • targetRectangle
    • Type:Rect
GetIsUnloadingNode()
PegManagedPeerNoRef()
UnpegManagedPeerNoRef()
GetManagedReference(UInt32)
  • nPropertyID
    • Type:UInt32
RefreshExpression(DependencyProperty)
  • dp
EnsureValueTable()
SetValueInternal(DependencyProperty,Object)
  • dp
  • value
SetValueInternal(DependencyProperty,Object,Boolean)
  • dp
  • value
  • allowReadOnlySet
SetValueInternal(DependencyProperty,Object,Boolean,Boolean)
  • dp
  • value
  • allowReadOnlySet
  • isBindingInStyleSetter
ClearValueInternal(DependencyProperty)
  • dp
ReadLocalValueInternal(DependencyProperty)
  • dp
IsPropertyDefault(DependencyProperty)
  • dp
GetMentor()
PrepareCorePropertyExpression(DependencyProperty,Object)
  • property
  • value
InvalidateStyleBinding(DependencyProperty,Boolean&)
  • dp
  • hasLocalOrAnimatedValue
    • Type:Boolean&
SetValue(DependencyProperty,Matrix)
  • property
  • m
    • Type:Matrix
SetValue(DependencyProperty,Matrix3D)
  • property
  • m
    • Type:Matrix3D
SetValue(DependencyProperty,Point)
  • property
  • p
    • Type:Point
SetValue(DependencyProperty,DependencyObject)
  • property
  • doh
SetValue(DependencyProperty,Int32)
  • property
  • i
SetValue(DependencyProperty,Boolean)
  • property
  • b
SetValue(DependencyProperty,Enum)
  • property
  • e
    • Type:Enum
SetValue(DependencyProperty,Color)
  • property
  • c
    • Type:Color
SetValue(DependencyProperty,Double)
  • property
  • d
SetValue(DependencyProperty,GridLength)
  • property
  • g
    • Type:GridLength
InvalidateProperty(DependencyProperty)
  • property
GetOldValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • oldEntry
    • Type:EffectiveValueEntry&
GetNewValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • newEntry
SetEffectiveValue(DependencyProperty,EffectiveValueEntry&,Object)
  • property
  • newEntry
  • newValue
UpdateParentInheritanceContextPropagation()
SetAnimatedValue(DependencyProperty,Object)
  • property
  • animatedValue
ClearAnimatedValue(DependencyProperty,Boolean,Object)
  • property
  • hasHoldEndValue
  • holdEndValue
OnInheritanceContextChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
AddEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
AddEventListener(DependencyProperty,Delegate,Boolean)
  • property
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
UpdateTreeParent(IManagedPeer,IManagedPeer,Boolean,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
  • bIsNewParentAlive
  • keepReferenceToParent
UpdateTreeParentHelper(IManagedPeer,IManagedPeer,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
IsPropertyLocal(CoreDependencyProperty)
  • dp
    • Type:CoreDependencyProperty
OnParentEnter(IntPtr,UInt32,UInt32,UInt32,UInt32)
  • nativeNamescopeOwner
    • Type:IntPtr
  • bLive
    • Type:UInt32
  • bSkipNameRegistration
    • Type:UInt32
  • bCoercedIsEnabled
    • Type:UInt32
  • bUseLayoutRounding
    • Type:UInt32
Source
Gets or sets the virtual path of your company logo image.
This property specifies where your company's logo image is. This the path that is related to you website root.
  • Type:ImageSource
IsEnabled
FontSize
FontFamily
  • Type:FontFamily
FontWeight
  • Type:FontWeight
FontStyle
  • Type:FontStyle
FontStretch
  • Type:FontStretch
CharacterSpacing
Foreground
  • Type:Brush
IsTabStop
TabIndex
TabNavigation
  • Type:KeyboardNavigationMode
Template
  • Type:ControlTemplate
Padding
  • Type:Thickness
HorizontalContentAlignment
  • Type:HorizontalAlignment
VerticalContentAlignment
  • Type:VerticalAlignment
Background
  • Type:Brush
BorderThickness
  • Type:Thickness
BorderBrush
  • Type:Brush
Triggers
  • Type:TriggerCollection
Resources
  • Type:ResourceDictionary
ActualWidth
ActualHeight
Width
Height
MinWidth
MaxWidth
MinHeight
MaxHeight
HorizontalAlignment
VerticalAlignment
Margin
  • Type:Thickness
Style
  • Type:Style
Parent
FlowDirection
  • Type:FlowDirection
Tag
Cursor
  • Type:Cursor
Language
  • Type:XmlLanguage
DataContext
AllowDrop
Opacity
Clip
  • Type:Geometry
Effect
  • Type:Effect
Projection
  • Type:Projection
OpacityMask
  • Type:Brush
RenderTransformOrigin
  • Type:Point
IsHitTestVisible
Visibility
  • Type:Visibility
RenderSize
  • Type:Size
UseLayoutRounding
CacheMode
  • Type:CacheMode
DesiredSize
  • Type:Size
RenderTransform
  • Type:Transform
Dispatcher
  • Type:Dispatcher
Map
ImplementationRoot
DefaultStyleKey
TagInternal
TemplatedParent
IsDataContextBound
IsDataContextChangingInternal
ChildrenInternal
  • Type:UIElementCollection
NativeObject
  • Type:IntPtr
NativeObjectSafeHandle
  • Type:NativeObjectSafeHandle
NeedsInheritanceContextChanges
IsInLiveTree
IsEnabledChanged N/A
Event Arguments:
Loaded N/A
Event Arguments:
Unloaded N/A
Event Arguments:
SizeChanged N/A
Event Arguments:
LayoutUpdated N/A
Event Arguments:
BindingValidationError N/A
Event Arguments:ValidationErrorEventArgs
DataContextChanged N/A
Event Arguments:
MouseMove N/A
Event Arguments:
MouseEnter N/A
Event Arguments:
MouseLeave N/A
Event Arguments:
MouseLeftButtonDown N/A
Event Arguments:
MouseLeftButtonUp N/A
Event Arguments:
MouseRightButtonDown N/A
Event Arguments:
MouseRightButtonUp N/A
Event Arguments:
MouseWheel N/A
Event Arguments:
KeyUp N/A
Event Arguments:
KeyDown N/A
Event Arguments:
MediaCommand N/A
Event Arguments:
GotFocus N/A
Event Arguments:
LostFocus N/A
Event Arguments:
LostMouseCapture N/A
Event Arguments:
TextInput N/A
Event Arguments:
TextInputStart N/A
Event Arguments:
TextInputUpdate N/A
Event Arguments:
DragEnter N/A
Event Arguments:
DragLeave N/A
Event Arguments:
DragOver N/A
Event Arguments:
Drop N/A
Event Arguments:
ManipulationStarted N/A
Event Arguments:ManipulationStartedEventArgs
ManipulationDelta N/A
Event Arguments:ManipulationDeltaEventArgs
ManipulationCompleted N/A
Event Arguments:ManipulationCompletedEventArgs
Tap N/A
Event Arguments:GestureEventArgs
DoubleTap N/A
Hold N/A
thinkgeo.mapsuite.silverlightedition.logomaptool.1442806098.txt.gz · Last modified: 2015/09/21 03:28 by admin
