<!– Class –> This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
*System.Object **ThinkGeo.MapSuite.SilverlightEdition.InteractiveResult
![]() | This is the default constructor of this parameter. | ||
![]() | InteractiveOverlayDrawType, ProcessOtherOverlaysMode | This is the commonly used constructor. |
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | InteractiveOverlayDrawType | This property gets and sets the DrawThisOverlay type to indicicate to draw this overlay or not. | |
![]() | RectangleShape | This property gets and sets the new current extent if the interative action affect the extent. | |
![]() | ProcessOtherOverlaysMode | This property gets and sets the DrawThisOverlay type to indicicate how to process other overlays. |
Name | Type | Description |
interactiveOverlayDrawType | InteractiveOverlayDrawType<!– ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlayDrawType –> | This parameter specified the interactiveOverlayDrawType to construct the class. |
processOtherOverlays | ProcessOtherOverlaysMode<!– ThinkGeo.MapSuite.SilverlightEdition.ProcessOtherOverlaysMode –> | This parameter specified the processOtherOverlays to construct the class. |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.SilverlightEdition.InteractiveResult –> Go Back
Return Type |
RectangleShape<!– ThinkGeo.MapSuite.SilverlightCore.RectangleShape –> |
Return Type |
