thinkgeo.mapsuite.silverlightcore.textstyles
ThinkGeo.MapSuite.SilverlightCore.TextStyles
    • ThinkGeo.MapSuite.SilverlightCore.TextStyles
CreateSimpleTextStyle(String,String,Single,GeoFontWeight,GeoColor,GeoColor,Single)
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • fontColor
  • haloPenColor
  • haloPenWidth
    • Type:Single
CreateSimpleTextStyle(String,String,Single,Boolean,GeoColor,GeoColor,Single,Single,Single)
Get simple TextStyle.
  • Type:TextStyle
  • Description:The desired TextStyle.
  • textColumnName
    • Description:The string stands for the column name.
  • fontFamilyName
    • Description:The string stands for the font family name. For example : “Arial”.
  • fontSize
    • Type:Single
    • Description:The float number stands for the font size.
  • isItalic
  • fontColor
    • Type:GeoColor
    • Description:The GeoColor used to set the font color.
  • haloPenColor
    • Type:GeoColor
    • Description:The GeoColor used to set the halopen color.
  • haloPenWidth
    • Type:Single
    • Description:The float value to set the halopen width value.
  • xOffset
    • Type:Single
    • Description:The float value stands for the xOffset of the font on the map in pixel
  • yOffset
    • Type:Single
    • Description:The float value stands for the yOffset of the font on the map in pixel
CreateMaskTextStyle(String,String,Single,Boolean,GeoColor,GeoColor)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
  • maskFillColor
    • Type:GeoColor
    • Description:The GeoColor used to set the mask fill color.
CreateMaskTextStyle(String,String,Single,Boolean,GeoColor,GeoColor,Single,Single)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
  • maskFillColor
    • Type:GeoColor
  • xOffset
    • Type:Single
  • yOffset
    • Type:Single
CreateMaskTextStyle(String,GeoFont,GeoSolidBrush,AreaStyle,Single,Single)
  • Type:TextStyle
  • textColumnName
  • textFont
    • Type:GeoFont
    • Description:The GeoFont used to set the font of the text.
  • textBrush
    • Description:The GeoSolidBrush used to set the brush of the text.
  • areaStyle
    • Type:AreaStyle
    • Description:The areaStyle used as mask of of the TextStyle.
  • xOffset
    • Type:Single
  • yOffset
    • Type:Single
CreateMaskTextStyle(String,String,Single,Boolean,GeoColor,GeoColor,Single)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
  • maskPenColor
    • Type:GeoColor
    • Description:The GeoColor used to set the mask pen color.
  • maskPenSize
    • Type:Single
    • Description:The float value used to set the mask pen size.
CreateMaskTextStyle(String,String,Single,Boolean,GeoColor,GeoColor,Single,Single,Single)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
  • maskPenColor
    • Type:GeoColor
  • maskPenSize
    • Type:Single
  • xOffset
    • Type:Single
  • yOffset
    • Type:Single
City1(String)
Get the commonly-used city TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • Description:The desired commonly-used Textstyle.
  • textColumnName
    • Description:The column name in the DBF that contains the text you wish to display on the label.
City2(String)
  • Type:TextStyle
  • textColumnName
City3(String)
  • Type:TextStyle
  • textColumnName
City4(String)
  • Type:TextStyle
  • textColumnName
City5(String)
  • Type:TextStyle
  • textColumnName
City6(String)
  • Type:TextStyle
  • textColumnName
City7(String)
  • Type:TextStyle
  • textColumnName
Capital1(String)
Get the commonly-used capital TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Capital2(String)
  • Type:TextStyle
  • textColumnName
Capital3(String)
  • Type:TextStyle
  • textColumnName
NoData1(String)
Get the commonly-used nodata TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Water1(String)
Get the commonly-used water TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Water2(String)
  • Type:TextStyle
  • textColumnName
Military1(String)
Get the commonly-used military TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Wildlife1(String)
Get the commonly-used wildlife TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
State1(String)
Get the commonly-used state TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
State2(String)
  • Type:TextStyle
  • textColumnName
Swamp1(String)
Get the commonly-used swamp TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Swamp2(String)
  • Type:TextStyle
  • textColumnName
Urban1(String)
Get the commonly-used urban TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Urban2(String)
  • Type:TextStyle
  • textColumnName
Country1(String)
Get the commonly-used country TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Country2(String)
  • Type:TextStyle
  • textColumnName
County1(String)
Get the commonly-used county TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
County2(String)
  • Type:TextStyle
  • textColumnName
Antarctical(String)
Get the commonly-used antarctical TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Evergreen1(String)
Get the commonly-used evergreen TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Evergreen2(String)
  • Type:TextStyle
  • textColumnName
Grass1(String)
Get the commonly-used grass TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
WaterIntermittent1(String)
Get the commonly-used waterIntermittent TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Sand1(String)
Get the commonly-used sand TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
SeaIce1(String)
Get the commonly-used seaice TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
SnowIce1(String)
Get the commonly-used snowice TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Tundra1(String)
Get the commonly-used tundra TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Crop1(String)
Get the commonly-used crop TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Forest1(String)
Get the commonly-used forest TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Park1(String)
Get the commonly-used park TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
LocalRoad1(String)
Get the commonly-used localroad TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
LocalRoad2(String)
  • Type:TextStyle
  • textColumnName
LocalRoad3(String)
  • Type:TextStyle
  • textColumnName
LocalRoad4(String)
  • Type:TextStyle
  • textColumnName
SecondaryRoad1(String)
Get the commonly-used secondary road TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
SecondaryRoad2(String)
  • Type:TextStyle
  • textColumnName
MajorStreet1(String)
Get the commonly-used major street TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
MajorStreet2(String)
  • Type:TextStyle
  • textColumnName
MajorStreet3(String)
  • Type:TextStyle
  • textColumnName
MajorRoad1(String)
Get the commonly-used major road TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
MajorRoad2(String)
  • Type:TextStyle
  • textColumnName
MajorRoad3(String)
  • Type:TextStyle
  • textColumnName
MajorRoad4(String)
  • Type:TextStyle
  • textColumnName
Highway1(String)
Get the commonly-used highway TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Highway2(String)
  • Type:TextStyle
  • textColumnName
Highway3(String)
  • Type:TextStyle
  • textColumnName
Highway4(String)
  • Type:TextStyle
  • textColumnName
Highway5(String)
  • Type:TextStyle
  • textColumnName
Interstate1(String)
Get the commonly-used interstate TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Interstate2(String)
  • Type:TextStyle
  • textColumnName
Interstate3(String)
  • Type:TextStyle
  • textColumnName
Interstate4(String)
  • Type:TextStyle
  • textColumnName
InternationalBorder1(String)
Get the commonly-used internationalBorder TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
InternationalBorder2(String)
  • Type:TextStyle
  • textColumnName
Railway1(String)
Get the commonly-used railway TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Railway2(String)
  • Type:TextStyle
  • textColumnName
Railway3(String)
  • Type:TextStyle
  • textColumnName
Railway4(String)
  • Type:TextStyle
  • textColumnName
StateBorder1(String)
Get the commonly-used state border TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
River1(String)
Get the commonly-used state river TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
River2(String)
  • Type:TextStyle
  • textColumnName
Canal1(String)
Get the commonly-used state canal TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
ContestedBorder1(String)
Get the commonly-used state contested border TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
ContestedBorder2(String)
  • Type:TextStyle
  • textColumnName
DegreeLine1(String)
Get the commonly-used state degree line TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Equator1(String)
Get the commonly-used state equator TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
RiverIntermittent1(String)
Get the commonly-used river intermittent TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Pipeline1(String)
Get the commonly-used pipeline TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Pipeline2(String)
  • Type:TextStyle
  • textColumnName
Pipeline3(String)
  • Type:TextStyle
  • textColumnName
Utility1(String)
Get the commonly-used utility TextStyle based on the given columnName point-type data.
  • Type:TextStyle
  • textColumnName
Utility2(String)
  • Type:TextStyle
  • textColumnName
Utility3(String)
  • Type:TextStyle
  • textColumnName
CreateSimpleTextStyle(String,String,Single,Boolean,GeoColor)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
CreateSimpleTextStyle(String,String,Single,Boolean,GeoColor,Single,Single)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
  • xOffset
    • Type:Single
  • yOffset
    • Type:Single
CreateSimpleTextStyle(String,String,Single,GeoFontWeight,GeoColor,Single,Single)
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • fontColor
  • xOffset
    • Type:Single
  • yOffset
    • Type:Single
CreateSimpleTextStyle(String,String,Single,Boolean,GeoColor,GeoColor,Single)
  • Type:TextStyle
  • textColumnName
  • fontFamilyName
  • fontSize
    • Type:Single
  • isItalic
  • fontColor
    • Type:GeoColor
  • haloPenColor
    • Type:GeoColor
  • haloPenWidth
    • Type:Single
thinkgeo.mapsuite.silverlightcore.textstyles.1442805884.txt.gz · Last modified: 2015/09/21 03:24 by admin
