thinkgeo.mapsuite.silverlightcore.inmemoryfeaturelayer
ThinkGeo.MapSuite.SilverlightCore.InMemoryFeatureLayer
This layer is backed by memory and is typically used for temporary features.
    • ThinkGeo.MapSuite.SilverlightCore.Layer
      • ThinkGeo.MapSuite.SilverlightCore.FeatureLayer
        • ThinkGeo.MapSuite.SilverlightCore.InMemoryFeatureLayer
InMemoryFeatureLayer()
If you use this constructor, then you need to specify the FeatureSource column manually.
InMemoryFeatureLayer(IEnumerable<FeatureSourceColumn>,IEnumerable<Feature>)
  • featureSourceColumns
    • Type:IEnumerable<FeatureSourceColumn>
    • Description:This parameter is the FeatureSourceColumn in this class that you want to use.
  • features
    • Type:IEnumerable<Feature>
    • Description:This parameter represents the features in this class that you want to use.
InMemoryFeatureLayer(IEnumerable<FeatureSourceColumn>,IEnumerable<BaseShape>)
  • shapes
    • Type:IEnumerable<BaseShape>
    • Description:This parameter represents the shapes in this class that you want to use.
GetColumns()
This method returns the columns of data for the InternalFeatures in this Layer.
You should set the column names for the data that the InternalFeatures will hold. For example, if you have some features that represent road signs, then one column you may want to add is “Sign Type”. Then, for every Feature you add to the layer, you need to add the “Sign Type” and a value to the InternalFeatures' ColumnValues dictionary. If you provide this information, then you can use things like ValueStyles, Labeling, etc. based on the columns you have defined.
BuildIndex()
This method build a spatial index for a passed group of featurs which increases access speed.
Open()
Close()
GetBoundingBox()
OpenCore()
  • Description:None
SetupTools()
SetupToolsCore()
CloseCore()
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
Columns
This property gets the columns of data for the InternalFeatures in this Layer.
InternalFeatures
This property gets the dictionary that holds your InternalFeatures.
The dictionary is a quick way to access your InternalFeatures. You can easily add, remove or edit features in this dictionary and they instantly take effect in the layer. You can always use the EditTools to do the same thing, but this is a shortcut, as the data is backed in memory so it is very pliable.
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In InMemoryFeatureLayer, we override this API and mark it as true.
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
FeatureSource
ZoomLevelSet
DrawingMarginPercentage
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
DrawingExceptionMode
IsOpenCore
DrawingFeatures N/A
DrawingWrappingFeatures N/A
DrawingProgressChanged N/A
thinkgeo.mapsuite.silverlightcore.inmemoryfeaturelayer.1442805705.txt.gz · Last modified: 2015/09/21 03:21 by admin
