This constructor is the default, but should not be used.
This is the constructor that should be used.
FeatureSourceColumn(String,String,Int32)
This is the constructor to create a FeatureSourceColumn.
This property is freeform and the type name is not tied to anything. It is wise to try and use familiar type names such as string, integer, date, etc., although it may not fit every different type of FeatureSource. We suggest thar you avoid using this property unless you know the types beforehand or simply want them for display purposes.
The maximum length is user defined and not in any way enforced in our default FeatureSource implementation. It is mainly for display purposes or when dealing with a known Feature Source type.
