thinkgeo.mapsuite.silverlightcore.drawingrectanglef
ThinkGeo.MapSuite.SilverlightCore.DrawingRectangleF
This structure represents the drawing of a rectangle in screen coordinates.
    • System.ValueType
      • ThinkGeo.MapSuite.SilverlightCore.DrawingRectangleF
DrawingRectangleF(Double,Double,Double,Double)
This method represents the constructor that should be used to create the structure.
  • centerX
    • Description:This parameter represents the center horizontal value of the rectangle.
  • centerY
    • Description:This parameter represents the center vertical value of the rectangle.
  • width
    • Description:This parameter represents the width of the rectangle.
  • height
    • Description:This parameter represents the height of the rectangle.
This method is an override of the Equals functionality.
This method is an override of the GetHashCode functionality.
CenterX
CenterY
Width
This parameter returns the width of the rectangle.
Height
This parameter returns the height of the rectangle.
thinkgeo.mapsuite.silverlightcore.drawingrectanglef.1442805618.txt.gz · Last modified: 2015/09/21 03:20 by admin
