thinkgeo.mapsuite.routing.routesegment
ThinkGeo.MapSuite.Routing.RouteSegment
This class repesents a routeSegment, which is a base element in routing.
    • ThinkGeo.MapSuite.Routing.RouteSegment
RouteSegment()
This is the default constructor for the class.
RouteSegment(String,Int32,Single,PointShape,IEnumerable<String>,PointShape,IEnumerable<String>)
This constructor allows you to provide the information for the routeSegment.
  • featureId
    • Description:This parameter is the feature ID of the routeSegment. It is an identity of a single routeSegment, thus you cannot set the feature ID to two or more routeSegments.
  • routeSegmentType
    • Description:This parameter specifies the type of routeSegment. You can define a value that represents kind of routeSegment, for example: 0 represents a local routeSegment, 1 represents a major routeSegment, 2 represents a highway.
  • weight
    • Type:Single
    • Description:This parameter is the weight of the routeSegment. It can represent, for example, the routeSegment length.
  • startPoint
    • Description:This parameter is the starting vertex of the routeSegment.
  • startPointAdjacentIds
    • Type:IEnumerable<String>
    • Description:This parameter is the adjacent feature IDs of the start point.
  • endPoint
    • Description:This parameter is the ending vertex of the routeSegment.
  • endPointAdjacentIds
    • Description:This parameter is the adjacent feature IDs of the end point.
hxQ=()
Distance
  • Type:Single
Weight
Gets or sets a value representing the weight of the routeSegment. It can represent, for example, the routeSegment length.
  • Type:Single
RouteSegmentType
Gets or sets a value representing the type of routeSegment. You can define a value that represents kind of routeSegment, for example: 0 represents a local routeSegment, 1 represents a major routeSegment, 2 represents a highway.
StartPoint
Gets or sets a value representing the starting vertex of the routeSegment.
StartPointAdjacentIds
Gets a value represents the adjacent feature ids of start point.
  • Type:Collection<String>
EndPoint
Gets or sets a value representing the ending vertex of the routeSegment.
EndPointAdjacentIds
Gets a value representing the adjacent feature IDs of the end point.
FeatureId
Gets or sets a value representing the feature ID of the routeSegment. It is an identity of a single routeSegment, thus you cannot set the feature ID to two or more routeSegments.
DrivingDirection
Gets or sets a value representing the next driving direction of the routeSegment. For example, if you are driving on the current routeSegment and will turn right on the next routeSegment, the value will be Right.
thinkgeo.mapsuite.routing.routesegment.1442545590.txt.gz · Last modified: 2015/09/18 03:06 by admin
