thinkgeo.mapsuite.portablecore.worldfile
ThinkGeo.MapSuite.PortableCore.WorldFile
<!– Class –> This class represents the values of a world file.
A world file is an attribute file that is associated with a corresponding image file. Typically, the world file consists of 6 lines of numbers.
Public MethodWorldFile This is the default constructor for the WorldFile class.
Public MethodWorldFile String This is the constructor that passes the worldFile text.
Public MethodWorldFile RectangleShape, Single, Single This is the constructor that passes the WorldExtent of the image, the height of the image, and the width of the image.
Public MethodWorldFile Double, Double, Double, Double, Double, Double This is a constructor that passes 6 attributes in double associated with the corresponding image file.
Public MethodWorldFile Single, Single, Single, Single, Single, Single This is a constructor that passes 6 attributes in float associated with the corresponding image file.
Public MethodGetBoundingBox Single, Single
Public MethodGetType Object
Public MethodToString Object
Public PropertyHorizontalResolution Single This property gets the horizontal resolution from the world file.
Public PropertyRotationColumn Single This property gets the rotation in column from the world file.
Public PropertyRotationRow Single This property gets the rotation in row from the world file.
Public PropertyUpperLeftX Single This property gets the upper left Y coordinate from the world file.
Public PropertyUpperLeftY Single This property gets the upper left X coordinate from the world file.
Public PropertyVerticalResolution Single This property gets the vertical resolution from the world file.
WorldFile()
Name Type Description
Go Back
WorldFile(String)
The worldFileText is typically read from a world file.
worldFileText String<!– System.String –> The world file text containing the world file attribute information.
Go Back
WorldFile(RectangleShape, Single, Single)
worldExtent RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> This parameter specifies the World Coordinate Extent for the image.
imageWidth Single<!– System.Single –> This parameter specifies the image width for the image.
imageHeight Single<!– System.Single –> This parameter specifies the image height for the image.
Go Back
WorldFile(Double, Double, Double, Double, Double, Double)
horizontalResolution Double<!– System.Double –> This parameter specifies the size of pixels in the x direction.
rotationRow Double<!– System.Double –> This parameter specifies the rotation term for row.
rotationColumn Double<!– System.Double –> This parameter specifes the rotation term for column.
verticalResolution Double<!– System.Double –> This parameter specifies the size of pixels in the y direction.
upperLeftX Double<!– System.Double –> This parameter represents the x coordinate of the center of the upper-leftmost pixel in map units.
upperLeftY Double<!– System.Double –> This parameter represents the y coordinate of the center of the upper-leftmost pixel in map units.
Go Back
WorldFile(Single, Single, Single, Single, Single, Single)
horizontalResolution Single<!– System.Single –> This parameter specifies the size of pixels in the x direction.
rotationRow Single<!– System.Single –> This parameter specifies the rotation term for row.
rotationColumn Single<!– System.Single –> This parameter specifes the rotation term for column.
verticalResolution Single<!– System.Single –> This parameter specifies the size of pixels in the y direction.
upperLeftX Single<!– System.Single –> This parameter represents the x coordinate of the center of the upper-leftmost pixel in map units.
upperLeftY Single<!– System.Single –> This parameter represents the y coordinate of the center of the upper-leftmost pixel in map units.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetBoundingBox(Single, Single)
width Single<!– System.Single –>
height Single<!– System.Single –>
<!– ThinkGeo.MapSuite.PortableCore.WorldFile –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
Void<!– System.Void –>
Return Type
RotationColumn
Return Type
RotationRow
Return Type
UpperLeftX
Return Type
UpperLeftY
Return Type
VerticalResolution
Return Type
thinkgeo.mapsuite.portablecore.worldfile.1440040133.txt.gz · Last modified: 2015/09/21 08:21 (external edit)
