thinkgeo.mapsuite.portablecore.worldfile
ThinkGeo.MapSuite.Core.WorldFile
This class represents the values of a world file.
    • ThinkGeo.MapSuite.Core.WorldFile
WorldFile()
  • This is the default constructor for the WorldFile class.
  • None
WorldFile(String)
  • This is the constructor that passes the worldFile text.
  • The worldFileText is typically read from a world file.
  • worldFileText
    • Description:The world file text containing the world file attribute information.
WorldFile(RectangleShape,Single,Single)
  • This is the constructor that passes the WorldExtent of the image, the height of the image, and the width of the image.
  • worldExtent
    • Description:This parameter specifies the World Coordinate Extent for the image.
  • imageWidth
    • Type:Single
    • Description:This parameter specifies the image width for the image.
  • imageHeight
    • Type:Single
    • Description:This parameter specifies the image height for the image.
WorldFile(Double,Double,Double,Double,Double,Double)
  • This is a constructor that passes 6 attributes in double associated with the corresponding image file.
  • horizontalResolution
    • Description:This parameter specifies the size of pixels in the x direction.
  • rotationRow
    • Description:This parameter specifies the rotation term for row.
  • rotationColumn
    • Description:This parameter specifes the rotation term for column.
  • verticalResolution
    • Description:This parameter specifies the size of pixels in the y direction.
  • upperLeftX
    • Description:This parameter represents the x coordinate of the center of the upper-leftmost pixel in map units.
  • upperLeftY
    • Description:This parameter represents the y coordinate of the center of the upper-leftmost pixel in map units.
WorldFile(Single,Single,Single,Single,Single,Single)
  • This is a constructor that passes 6 attributes in float associated with the corresponding image file.
    • Type:Single
  • rotationRow
    • Type:Single
  • rotationColumn
    • Type:Single
    • Type:Single
  • upperLeftX
    • Type:Single
  • upperLeftY
    • Type:Single
GetBoundingBox(Single,Single)
  • width
    • Type:Single
  • height
    • Type:Single
HorizontalResolution
  • This property gets the horizontal resolution from the world file.
  • None
  • Type:Single
RotationRow
  • This property gets the rotation in row from the world file.
  • None
  • Type:Single
RotationColumn
  • This property gets the rotation in column from the world file.
  • None
  • Type:Single
VerticalResolution
  • This property gets the vertical resolution from the world file.
  • None
  • Type:Single
UpperLeftX
  • This property gets the upper left Y coordinate from the world file.
  • None
  • Type:Single
UpperLeftY
  • This property gets the upper left X coordinate from the world file.
  • None
  • Type:Single
thinkgeo.mapsuite.portablecore.worldfile.txt · Last modified: 2017/03/16 21:59 (external edit)
