<!– Class –> Represents an object that encapsulates a Web Map Service (WMS) layer.
A Web Map Service (WMS) produces maps of spatially referenced data dynamically from geographic information. This International Standard defines a “map” to be a portrayal of geographic information as a digital image file suitable for display on a computer screen. A map is not the data itself. WMS-produced maps are generally rendered in a pictorial format such as PNG, GIF or JPEG, or occasionally as vector-based graphical elements in Scalable Vector NativeGraphics (SVG) or Web Computer NativeGraphics Metafile (WebCGM) formats.
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.RasterLayer ThinkGeo.MapSuite.PortableCore.WmsRasterLayer
![]() | This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually. | ||
![]() | Uri | This is the constructor the for the class. | |
![]() | Uri, GeoWebProxy | This is the constructor the for the class. |
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | ScreenPointF | ||
![]() | ScreenPointF, String, Int32 | ||
![]() | ScreenPointF, String | ||
![]() | ScreenPointF, Int32 | ||
![]() | Object | ||
![]() | RasterLayer | This method returns the horizontal resolution of the image. | |
![]() | RasterLayer | This method returns the projection parameters of the current layer. | |
![]() | RectangleShape, Int32, Int32 | Get the request URL from the client to the WMS. | |
![]() | This API gets the GetCapabilites document of the service. | ||
![]() | This method returns the projected or geographic coordinate reference systems to be used. | ||
![]() | This method returns the exception format at the server side. | ||
![]() | This API gets the WMS server FeatureInfo formats of the service. | ||
![]() | This method returns the names of all layers at the server side. | ||
![]() | This method returns the output format at the server side. | ||
![]() | This method returns the names of all styles at the server side. | ||
![]() | This API gets the WMS server version of the service. | ||
![]() | Object | ||
![]() | RasterLayer | This method returns the vertical resolution of the image. | |
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | TimeSpan | Layer | |
![]() | RectangleShape | Layer | |
![]() | Layer | ||
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | ||
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | Collection<String> | This property represents the available layers that can be requested from the client and shown on the map. | |
![]() | Collection<String> | This property represents the available styles that can be requested from the client and shown on the map. | |
![]() | String | Layer | |
![]() | WmsAxisOrder | ||
![]() | Single | RasterLayer | This property gets and sets the amount of blue to apply to the image. |
![]() | TimeSpan | ||
![]() | ICredentials | This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication. | |
![]() | String | This property gets or sets the projected or geographic coordinate reference system to be used. | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | String | This property indicates the format in which the client wishes to be notified of service exceptions. | |
![]() | Single | RasterLayer | This property gets and sets the amount of green to apply to the image. |
![]() | Boolean | Layer(overriden) | This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | Boolean | RasterLayer | This property returns true if the RasterLayer contains projection parameters and false if it does not contain any projection parameters. |
![]() | RasterSource | RasterLayer | This property gets and sets the ImageSource used by the RasterLayer. |
![]() | Boolean | RasterLayer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | RasterLayer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | This property gets or sets whether the response map image's background color is transparent or not. | |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Collection<GeoColor> | RasterLayer | Gets a value represents a collection of key colors. If HasKeyColor property is false, it will throw exception when you use KeyColors. |
![]() | Double | RasterLayer | This property gets and sets the lower threshold in the scale at which to display the image. |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | String | This property gets or sets the desired output format for the map requested from the WMS. | |
![]() | Dictionary<String,String> | This property specifies a dictionary used to update the request sent from the client to the WMS server. | |
![]() | GeoWebProxy | This property gets or sets the proxy used for requesting a Web Response. | |
![]() | Single | RasterLayer | This property gets and sets the amount of red to apply to the image. |
![]() | Int32 | This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds. | |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | Double | RasterLayer | This property gets and sets the upper threshold in the scale at which to display the image. |
![]() | Uri | This property specifies the URI of the WMS server. |
Name | Type | Description |
This constructor initializes a new layer, then downloads and parses the service description. In an ASP.NET application, the service description is automatically cached for 24 hours when it is not specified.
uri | Uri<!– System.Uri –> | URI of the WMS server. |
proxy | GeoWebProxy<!– ThinkGeo.MapSuite.PortableCore.GeoWebProxy –> | Proxy to use for the current WMS layer. |
Return Type | Description |
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
Void<!– System.Void –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Dictionary<String,Collection<Feature»<!– System.Collections.Generic.Dictionary{System.String,System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.Feature}} –> |
screenPointF | ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> |
<!– ThinkGeo.MapSuite.PortableCore.WmsRasterLayer –> Go Back
screenPointF | ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> | |
infoFormat | String<!– System.String –> | |
maxFeatures | Int32<!– System.Int32 –> |
Single<!– System.Single –> | This method returns the horizontal resolution of the image. |
<!– ThinkGeo.MapSuite.PortableCore.RasterLayer –> Go Back
String<!– System.String –> | This method returns the projection parameters of the current layer. |
String<!– System.String –> | The request URL from the client to the WMS. |
worldExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
canvasWidth | Int32<!– System.Int32 –> | The returning map width, as well as the drawing canvas width. |
canvasHeight | Int32<!– System.Int32 –> | The returning map height, as well as the drawing canvas height. |
String<!– System.String –> | This API returns the GetCapabilites document of the service. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the exception format at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This API returns the FeatureInfo formats supported on the server-side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the names of all layers at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the output format at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the names of all styles at the server side. |
String<!– System.String –> | Returning a string reflecting the version of the service in WMS. |
Type<!– System.Type –> |
Single<!– System.Single –> | This method returns the vertical resolution of the image. |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
When requesting a map, a client may specify the layers to be shown on the map.
Return Type |
When requesting a map, a client may specify the styles to be shown on the map.
Return Type |
Return Type |
Return Type |
WmsAxisOrder<!– ThinkGeo.MapSuite.PortableCore.WmsAxisOrder –> |
Return Type |
Return Type |
Return Type |
ICredentials<!– System.Net.ICredentials –> |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
Return Type |
Return Type |
The override in the WmsRasterLayer sets it to true.
Return Type |
Return Type |
The set for this property is protected and only intended to be used by developers who are creating their own ImageSources. This is the main property to set for developers who are creating their own RasterLayer derivatives.
Return Type |
RasterSource<!– ThinkGeo.MapSuite.PortableCore.RasterSource –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.GeoColor} –> |
Below the lower threshold in scale, the image will not be displayed. This, in conjunction with the UpperThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type |
Double<!– System.Double –> |
Return Type |
When requesting a map, a client may specify the output format in which to show the map. Format are specified as MIME types such as “image/gif” or “image/png”.
Return Type |
Return Type |
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Above the upper threshold in scale, the image will not be displayed. This, in conjunction with the LowerThreshold property, allows you to create a band in which it is suitable to display the image source. By default, the upper threshold is double.max and lower threshold is double.min. This means the image should always display.
Return Type |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SendingWebRequestEventArgs –> |
Event Arguments |
SentWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SentWebRequestEventArgs –> |
